Thread: HELP!! Alternative for R-0871?
    Jun 2012
    Howard City, MI
    54
    I am shocking pool to get rid of algae. I am going through the R-0871 reagent very quickly since I am testing multiple times a day (at least two). I have ordered more but it won't be here for 3 more days. Is there anything else I can do to test my FC? I don't want to have made all this progress on my shocking and then go backwards because I am out of testing reagent.
    PLEASSE HELP!
    Above-Ground Pro Series 18'x48" Metal Frame - Approx 6,450 gallons
    Skimmer Filter System (cartridge): SFS1000 w/ F1500C Pump: 120watts/2.0amps/1500g.p.h
    Purchased & Installed: 6/7/12 (week of)
    Re: HELP!! Alternative for R-0871?
    By using 5 ml of pool water, instead of 10 ml, you can measure FC so that each drop of R-0871 is 1 ppm, which uses half as much reagent, but is a bit less precise.
