Thread: AGP vacuum hose circumference / skimmer port circumference ?
    Jul 2010
    Raleigh, NC
    60
    I have hard plumbed 1 1/2" PVC and instead of the Intex fittings we used these
    http://www.poolpartsonline.com/p-241-ha ... parts.aspx
    It's my understand (maybe wrong) that Wanda the Whale / Diver Dan uses standard size vacuum hoses & the hose is made to fit into the skimmer (hence the cone it comes with)
    http://www.poolsupplyworld.com/Hayward- ... 7AodWncAYg
    That's all well & great except we don't have a thru-the-wall skimmer so I'm trying to find something that will screw into the Hayward 1 1/2" fitting and will also fit inside the vacuum hose (to keep the suction strong).
    I have been unable to find anything that states the circumference of the vacuum hose ... anyone know what this is?
    So far, I have come up with using this http://www.poolproducts4less.com/swimmi ... -hose.html
    but it seems the hose it going to stop here and even with a clamp I'll lose lots of suction.
    Thoughts / suggestions ?
    26' x 52" Intex Ultra Frame (14,667 gallons), Hayward Matrix 1hp 2speed, Hayward ProSeries 21" sand filter
    1.5" PVC piping with in-wall skimmer, TF100 test kit
    City water in Raleigh, NC
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Re: AGP vacuum hose circumference / skimmer port circumferen
    I use one of these on my DiverDan and the standard Hayward segmented hoses. The last hose has a special fitting for attach to cleaner body (Dan/Dave?). I have not used a standard vacuum hose with my bots but I thought the bot needed a rigid (non-rotating) cuff to allow it to turn in the pool. I know my hose gets a little twisted and tight is I run it for several hours.
    -- Guy --
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    I forgot... this cone adapts the hose to bottom of my skimmer. It would also likely seal up with that fitting you have in your pool.
    -- Guy --
