Results 1 to 20 of 20
Thread: Newbie first TFT kit use - results
    Howdy!
    I just got my TF test kit this week and have performed my first test today.
    I didn't realize my chlorine tower was empty, and I don't know what effect that will have on my results.
    My first set of results are as follows
    Total Alkalinity - 180
    Ph is approx 7.8
    Ca hardness is 800
    CYA is 100
    Could you please give me an idea of what products I'll need to add?
    Thanks!
    Charlie
    25k I G plaster pool w/spa. 2.2HP Century Centurion switchless motor. COMPOOL lx3800. Pentair FNS Plus DE FILTER 60sq/ft.
    Houston, TX - direct sunlight 8 hours a day.
    kkendall's Avatar
    Phoenix
    67
    Re: Newbie first TFT kit use - results
    Might want to consider getting a baseline of your tap water of TA & CH
    If it comes to doing a partial drain, you'll have a good idea what will be going back in
    * 18.5 K Gallon, 8ft deep, IG, Pebble Radiance * Pentair VS 3050 Pump w/420 Cartridge Filter
    * Blue Square Q-360 In-floor Cleaning System * UltraPure UPP25 Ozone Generator
    * Pool startup: 09-04-2012 * TF-100 Test Kit
    30,419
    Hi, Charlie,
    You don't post your FC reading which is the most important.
    I assume you mean a puck feeder when you say chlorine tower. Hold off on reloading that. Your CYA is way too high right now and the pucks will only contribute further to that excess.
    Put your FC test result up and let's go from ther. I can tell you in advance that we are gonna' suggest a partial drain/refill to reduce the CYA.
    Butterfly's Avatar
    South Carolina
    10,045
    We may need to talk more about what products to take away!
    What product do you put in the chlorine tower?
    Did you test chlorine using the oto/yellow drop test?
    Did you test FC/CC using the FAS/DPD tests?
    Please read the Extended Test Kit Directions here and do the CH and CYA tests for high readings.
    extended-test-kit-directions-t25081.html
    It would also be very helpful to test your fill water for TA & CH as mentioned.
    You are going to need to do the water dance to lower some chems.
    But first, let's confirm the test results to make sure.
    BTW, how old is your pool?
    You're done SLAMing when:
    Ah....
    I didn't run that test as I noticed I had no chlorine tablets in the tower.....
    I have since added 3" tabs to the tower and two scoops of shock.
    The current results are FC - 17.5 and CC - 2.5 so a TC of 20....
    Thanks!
    30,419
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by charlieTX
    Ah....
    Thanks!
    As duraleigh said, the tabs will only raise CYA more, which is already too high. The "scoop shock", prob dichlor, will also raise CYA more. You gotta switch to bleach/liquid chlorine so that you stop adding to the problem!
    But first, you still need to confirm the CYA level. If you are confident in the test reults, you will need to dump/refill about half the pool. Once you get that under control, you need to complete the shock process. Pool School has clear directions to accomplish this.
    Getting the recommended test kit was the first big step.
    Smykowski's Avatar
    Sep 2011
    3,065
    Stop using solid chlorine. Bleach/liquid chlorine only from now on.
    Thanks for help guys.
    Butterfly - I think the pool is around 10 years old.
    Currently draining the pool.... I have a large bucket of 3' solid chlorine tablets
    How should I dispose of those?
    My last few visits to the pool store and they've told me everything was fine before I got my TF kit!
    With these levels is the pool still safe to swim in?
    Thanks again.
    38,275
    The pucks will last for years in the bucket. Hold on to them and use them if you need a CYA boost or for vacations.
    Well, you really need to know what your CYA level truly is to know if you are "safe".
    Have you pulled all the tablets out of the tower?
    You can run the CYA test with 50/50 split of pool and tap water and then mix with the reagent and double the reading to find out how high it really is.
    Given that you have a CC > 0.5, generally we would say the pool is not "safe" and you should go through the Shocking Your Pool PROCESS after lowering the CYA.
    Butterfly's Avatar
    South Carolina
    10,045
    okay
    Not to worry. Save them for vacations.
    How should I dispose of those? Nope, see above. Also, they last forever if they stay dry.
    I would not swim w/ 2.5 CC. Let us see the pH, FC, CC & CYA once you get some draining done.
    Thanks again.
    Folks here love to help
    30,419
    Hang on to them! We try to never waste anything at TFP. They will make a great back up source if used sparingly and they will last forever.
    Absolutely. Just keep a good amount (8 ppm or so) of chlorine in your pool (use bleach) and swim away.
    When your refill is complete, retest and post the results.....we'll help you get fine tuned for the rest of the summer.
    30,419
    Charlie,
    Confirm that your water is clear....correct?
    Charlie,
    Yes, the water looks fine. It's not as sparkly as usual, but looks good.
    Good morning!
    I drained off several inches of water and am currently refilling.
    I ran a quick test this morning.
    FC - 3.5
    CC - 0
    TA - 130
    CH - 650
    CYA is still around 100
    So I guess I need to drain more water.
    I'm heading to the store to buy liquid bleach. Approximately how many gallons am I going to need to add to shock the pool and get the FC up to the shock level of 39 as stated in the CY / FC chart?
    Thanks!
    Also, my pool is in direct Texas sunlight most of the day.
    38,275
    Use poolcalculator.com to determine how much bleach you will need to reach your target. I would highly suggest replacing a lot of water first.
    Butterfly's Avatar
    South Carolina
    10,045
    Yep, try to get down to about 50ish CYA.
    Howdy!
    I drained half the pool over the weekend.
    My new results are as follows
    FC - 4
    CC - 0
    TA - 150
    CH - 380
    CYA - 55
    Much better.... I am going to shock tomorrow!
    Thanks guys!
    Butterfly's Avatar
    South Carolina
    10,045
    Howdy!
    FC - 4
    CC - 0
    TA - 150
    CH - 380
    CYA - 55
    Thanks guys!
    Nice work! Why not raise to shock level tonight and do the OCLT tonight, too? oops, what's the pH?
  20. Back To Top    #20
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    I would start that shock tonight.
    Night time chlorine additions are more effective than daytime as the CL will only go to killing the algae that is making your pool cloudy. During the day, the sun drives off the FC (and the bad CC after the FC converts it).
    -- Guy --
