Thread: Anybody paint The Liquidator....
    I just received mine this week. My pool gets full sun throughout the afternoon. I'm just curious what some people did to block the Sun from affecting the chlorine in The Liquidator. If you painted it, what color did you use?
    Thanks.
    21' round, 10,000 gallons above ground vinyl pool. The Liquidator 8 gallon version.
    Aug 2010
    Dallas, TX
    4,052
    Re: Anybody paint The Liquidator....
    Painting them white is common. Put a strip of masking tape from top to bottom so that after you paint you can pull the tape and have a slit to see into the tank to see where the chlorine level is at.
    Sep 2011
    Plant City, Florida
    38
    I put a strip of blue painters tape from bottom to top of mine, then painted the front and both sides black. Remove the and you have a "site window" to check the level.
