Page 1 of 2 12 LastLast
Results 1 to 20 of 29
Thread: This pool Chemical stuff is confusing
    Hello all,
    I might be dumb or not comprehending the chemical aspects of maintaining a pool. I have read the pool school and several other pages, but I just don't understand. I have a cloudy, green pool. I have the TF100 test and tested the water.
    My results are:
    CYA - 60
    FC - 8
    CC - 0
    TC - 8
    T/A - 150
    PH - 8.4
    From what I read, I "Think" my readings are ok. But why do I have a green pool?
    16344 gal, AG, Fijian 52 Pool 27' round w/ 1.5 HP 21 Sta-Rite Above Ground Pool Sand Filter System. using ZeoBest ZeoLite Filter Media.
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: This pool Chemical stuff is confusing
    Recommended levels are based on a clean pool and should be used for maintenance. If your pool is green, you have to shock it first.
    Your pH is way too high. Get it to 7.8 pronto.
    GreatCanadian's Avatar
    Jul 2011
    St. John's, Newfoundland
    844
    How long between adding chlorine and testing? If you have algae your CC should not read zero.
    13'x22'x52" 8,000 gallon ProSeries Pool with Borates
    Intex 110 pound Sand Filter with Zeobrite, 2650 gph pump, 0.95 hp
    Bestway SWG
    AquaPro ECO500 50,000 BTU heat pump
    GLI Whirlwind Solar Cover Reel, TF-100 Test Kit
    The pool was green with alge yesterday, day before yesterday we had a very hard rain. I tested yesterday and added 2 gallons of bleach to the pool.
    I woke up this morning, vacuumed the pool and tested again. I posted the results in my first post.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,374
    You need to complete the shock process to clear your pool. Please read the shock process and defeating algae for more information.
    Love TFP? Become a
    TFP Supporter!
    Jul 2011
    844
    I agree with you zea, but something isn't right. If he has algae, then his CC should NOT have been 0 this morning. And I doubt they were. There is something wrong with the test results.
    Bestway SWG
    The test Kit Chlorine Drop Test states.
    "5. To test for Combined Chloramines(CC), add 5 drops of R0003 to the solution and swirl. If it remains clear, you have no CC's. It it returns back to pink... blah, blah blah. "
    I added the 5 drops of R0003 and it remained clear. So I recorded as no CC.
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,760
    With PH that high, I am wondering if metal oxidization is possibly causing the color. Just a wild guess, but that would only be if there a) wasn't prior algae and b) chlorine never dropped below recommended level.
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
    Jul 2011
    844
    Icifers, you tested this morning and FC is 8. Can you test again and tell us the FC?
    Bestway SWG
    From the time that zea3 told me to shock the pool. I put in 2lbs of Blue Wave Chlor-Burst Fast-Dissolve shock. Because that is all I have at the time, I am waiting for my wife to come home from the store with bleach. I just took my readings and I have:
    FC - 13 - (26 Drops)
    CC - .5 - (1 drop).
    From what I read from the "http://www.troublefreepool.com/pool-school/shocking_your_pool" I need to get my Shock level up to 24.
    Jul 2011
    844
    Test again after 2 or 3 hours (let us know how long), and post again. I'm beginning to wonder if you really have algae
    Bestway SWG
    It's green, I can take a picture and post it.. if need be...
    30,395
    Pictures ALWAYS help. The important thing to note here is you are in a "process" not an occasional or intermittent dose of chlorine.
    Shock value FC must be maintained over a period of days and you must follow "How to Shock Your Pool" up in Pool School.
    Everyone is easily confused on this point. You must do all the things suggested over a period of days and your pool will turn crystal clear. That often takes patience and faith but hang in there....this will work.
    The only thing that changed since the hard rain we got and the pool turning green, I had ordered and recieved a "Pool Rover", to automatically clean the pool. Would that have cause the pool to turn green?
    30,395
    No. There is no cnnection.
    Thanks for the pics. What is that greenish discoloration in the center of your pool underneath the net? Does it brush up when your brush it or vacuum it?
    I couldn't reach that part with the pole, the whole pool bottom was covered with it this morning, it vacuumes up, but I need to get a longer pool extention to reach that part. Headed to the pool supply shop now to pick one up.
    30,395
    It's fine if you get in your pool when it below shock value by even just a little bit. Brushing and vacuuming is a VERY important part of the process and needs to be done anytime you observe stuff on the floor.
    Smykowski's Avatar
    Sep 2011
    3,065
    Quote Originally Posted by GreatCanadian
    Just to clarify, algae clearing does not necessarily throw off CCs. ChemGeek, please jump in if I'm wrong, but the major source of CCs (aka monochloramine, dichloramine, and nitrogen trichloride) is the oxidation of nitrogen based compounds like urea, ammonia, sweat, etc.
  20. Back To Top    #20
    Smykowski, you are correct. It is extremely common to have algae and have CC be zero.
    Metals are more likely to be the issue when the water is a clear transparent green. Algae is more likely when the pool is cloudy/murky. The photo looks more on the clear transparent side, but with a touch of cloudiness, so not definitive.
    An overnight FC loss test will clear things up. If you are losing chlorine overnight then it is algae. Otherwise it is probably metals in the water
