Thread: Piping for heater?
    Piping for heater?
    Is it ok to use those flexible plastic tubes with a pool heater or do we need to plumb the pool with PVC? I would think they would make the plastic tubes thick enough to handle a pool heater but I want to make sure. The order of equipment would be filter pump, heater, then the chlorine generator right?
    Thanks for your help in advance!
    22,549
    Re: Piping for heater?
    The hoses should be fine. The heater only heats the water a little warmer than the pool water so it doesn't get that hot.
    if it were me i would use pvc wouldnt cost 30 bucks or so then you know your fine
    15x30x54 AG,2HP2SP PUMP 400LB SAND FILTER
    ps0303's Avatar
    Jul 2011
    FL
    3,695
    It's OK to use the flexible if you really have to. What is your reasoning behind wanting to use them anyway as compared to the rigid PVC pipe?
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    We already have a bunch of flexible hose from old intex pools over the years, so I wouldn't need to buy anything at all.
    Mar 2013
    Yucaipa CA
    87
    Quote Originally Posted by cmp2993
    The order should be pump, filter, heater then chlorine generator.
    skeeter
    47 yr old(1977) 18,000gal Kidney shaped 38ft long plaster Pool with built-in Spa, Pentair Intelliflo VS3050 Pump, Pentair 48sf DE filter, Raypack RP2100 gas heater. HTH 5-way test kit
