Results 1 to 20 of 20
Thread: Shock Not Working
    Shock Not Working
    Hi, I'm new to the board. I've read pool school and I'm ready to ask my question.
    I have an algae problem that I can't control. I can see the bottom of the pool but its green. I shocked the pool (3 gallons of 8.25% bleach) plus 1 Lb Trichlor 5 days ago and it isn't improving.
    My assumption is that my Stabilizer (CYA) is too high and that I need to do a partial drain.
    Here are my numbers (it rained 2-3 inches last night). Please Help!
    FC - 5.4
    CC - 6.2
    PH - 7.2
    TA - 100
    CH - 150
    CYA - 70
    12,000 gal, AG, Sand Filter (Hayward S220T), 1 HP single speed
    TF-100
    Wilmington, NC
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,377
    Re: Shock Not Working
    Hi, welcome to TFP! Shocking is a process and not a one time application of product. You need to bring the pool to shock level and keep it there until the process is complete. Please read the shock process and defeating algae for more information.
    Yes, the CYA is a little high but it is still manageable at 70ppm. You just need to be sure that you are keeping the FC in the correct range for your pool. You can use the Pool calculator to help determine your correct levels for your pool.
    Love TFP? Become a
    TFP Supporter!
    For long term lower cost would it be worth trying to get my CYA down closer to 50? I have a well and it only costs a couple bucks worth of electricity to pump hundreds of gallons.
    Also, I was thinking CC was equivalent to Total Chlorine. I don't have a CC level that I'm aware of. The numbers I posted are from the pool store's analysis.
    TF-100
    Wilmington, NC
    38,251
    You really can not follow the shock process without one of the recommended test kits. That is why you claim it is not working, because you are not infact following the process.
    It would certainly help to lower the CYA first, but the CYA test just happens to be the test that pool stores get wrong the most often because they do not use the correct lighting.
    Get a kit. Take control.
    Just ordered the TF100 Kit. In the Meanwhile would an OTO test with diluted water be worth a try?
    TF-100
    Wilmington, NC
    38,251
    It can get you in the ballpark. If you ASSUME the CYA is in fact 70ppm, then you want to try to maintain your FC up around 20-28ppm. You will need to use 4 parts distilled water to 1 part pool water and multiply by 5 ... this is not very accurate, but will get you started.
    Or, you could assume the CYA is in fact 70ppm and replace 30-50% of your water to get the CYA more reasonable.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Quote Originally Posted by pezzdog
    Just to be sure - the Chlorine test is yellow, not pink, correct?
    If so...
    From my own research (which I hunted down here using search) Blinding yellow is about 10. School bus yellow is about 12-13. Hunter orange is around 18, up around 25 it starts to look pumpkin orange. I never went any higher than that, but it's been reliably reported that it eventually will turn brown if you get high enough.
    38,251
    And I think specs of brown will fall out of the water if you get even higher.
    Jun 2012
    Howell, NJ
    977
    When you get to automatic chlorinator levels, you get little clumps of red. Sort of like a lava lamp.
    John
    7 year old ~13,500 gal 24' AGP with 1.5 hp Proline pump, 150 sqft Pleatco cartridge, filled with well water with pH of about 4.5.
    Wanda the Whale pool vacuum, home made heater, Taylor K-2006
    Cloudy Pool? 1) Order test kit. 2) Follow SLAM
    New to TFPC? Read Pool School a few times, then post questions. PoolMath will help with chemical additions.
    Think this is somewhere in the 20-28 range? Still awaiting my TF-100 kit.
    TF-100
    Wilmington, NC
    Richard320's Avatar
    Jan 2010
    18,967
    That would be my guesstimation.
    Decided to do a partial drain. I drained 40% today and its refilling now. Hoping to get down to 40 CYA. Then its on to BBB from there.
    TF-100
    Wilmington, NC
    30,403
    Nice work, pezzdog.
    You're already joining the BBB club as you gain increased understanding of what you need to have crystal clear water....you will not regret that drain.
    Thanks Duraleigh! I noticed your name and that you're from Raleigh, NC. I grew up in Raleigh and frequently drove on Duraleigh Road.
    I'm anxious to add borates. Would it be detrimental to do that before I get rid of this outbreak? I'm already running the pump 24hrs right now so it seemed to be a good enough time (assuming my TA and PH are correct).
    TF-100
    Wilmington, NC
    Mar 2010
    Spring, TX
    1,082
    From my opinion reading on the site, I would concentrate on one thing at a time since you are shocking. Get the shocking out of the way then you can concentrate on adding borates.
    Just my opinion though as I am sure others will be along with more advice.
    13,000 Plaster IG Pool approx
    Hayward C5030 Cart Filter
    Emerson 1081 EB653 1.0 HP 1.40 S.F. 3450 RPM
    Pool Calculator, Pool School, TF Test Kits
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    You are still shocking, correct? Then don't add borates. You need to be able to test and adjust ph and ta to do that and you can't test them when FC is over 10 ppm. Why are you wanting to add borates?
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    Thanks. That makes sense. By borates I mean borax.
    TF-100
    Wilmington, NC
    Still awaiting my test TF100 kit. It was shipped today! Thank goodness...
    I just dropped by the local pool store to have them do a test because I'm still trying to get rid of this algae. I'm seeing moderate success (I'm finding out that the shock process is virtually impossible without good test equipment. I'm beginning to seriously doubt the pool store's test equipment. In my post above I had a CYA level of 70, after I did a 40% drain and refill their test came back with the same number! (I was hoping to see somewhere in the 42 range (assuming 60% of 70).
    Here are my numbers according to them, but I'm assuming my CYA is lower now.
    Total Chlorine - 10
    FC - 10
    pH - 8.1 (gotta fix this, but can this be accurate since FC is so high?)
    TA - 85
    CH - 150
    CYA - 70 (again, not sure about this one)
    They're telling me to use an Algaecide...I told them I'm trying to let the chlorine do its job.
    TF-100
    Wilmington, NC
    Aug 2010
    Dallas, TX
    4,052
    You are right to doubt the store. The biggest problem is inexperience, and then there's the fact they usually don't really care. And CYA is the one thing they seem to routinely get wrong.
    And again, you are right, let the chlorine do its job.
    It can take weeks to complete the shock process. Keep up the POP! (pool owner patience!)
    Ignore your pH for now.
  20. Back To Top    #20
    Test kit came! CYA = 80. The dude that sold me the house must have spent ungodly amounts on Cl to keep the pool clear. Maybe he "shocked" it with a ton of tri/dichlor before he put it on the market!
    Well I'm now doing another 40-50% water dump and replace. Stinking pool store testing at 70 cya when it was likely more like 130! I should have had patience and waited for my TF100 so I could test before I refilled. Would have saved thousands of gallons!
    So much for swimming over July 4th the water will probably be in the upper 60's. I hope I don't empty the well!
    TF-100
    Wilmington, NC
