Thread: Yellow Mustard and/or Pollen
    Jun 2013
    NE Florida
    2
    I have owned this house/pool for almost 4 years. The pool has a large ornamental bush/tree that provides privacy and aesthetics that extends over the pool. For 2-4 weeks each year (around May) the pollen and seed pods from this tree are bad enough to cause me to run the pump 24/7 and clean the cartridge filter daily. We had a mild winter here in NE Florida so this year the pollen drop started early (in March) and was not as intense as years past. A second pollen drop started in late May, again not intense, but enough to yellow the water. Besides running the pump and frequent cleanout of the traps/filter, I have previously had luck clearing up the pool with a product called Natural Chemistry's Pool First Aid. I treated the pool and it cleared up for a few days but became cloudy again. A second treatment cleared the pool up for a few days and then the cloudiness returned. A 3rd treatment had no impact. Like I mentioned, I have experienced the pollen drop enough to know that 24/7 filtering, frequent filter rinses and occasionally using this first aid stuff has worked well for 4 years, thus after the 3rd regiment I started to research other possibilities.
    Speculating that I may have Yellow Mustard, I began to shock the pool using ‘lots’ of liquid chlorine in 2.5 gallon jugs.
    After stumbling onto this forum, I quickly surmised that the test kit I had was too basic to determine CYA and higher levels of Chlorine. Yesterday, I picked up what I thought was the Leslie’s FAS-DPD only to find out it was an expensive DPD (only) kit which maxed out at 25ppm for chlorine. I am heading back to Leslie’s at lunch to see if they will swap the kit for the FAS-DPD. I don’t think they have it in stock, so may have to order one.
    For the past 5 days, I have been brushing the pool twice daily, cleaning the cartridge filter twice daily, and added socks to the skimmer baskets. The pool is improving and no longer yellow/green but it is still cloudy, though I can easily see the drain cover in the deep end (my test for cloudiness).
    I have read enough to know that I really need to have accurate chem readings to help determine next steps. As soon as I get the right kit, I’ll be able to effectively manage the shock levels , but wanted to type up a summary while I had an opportunity. Thanks for a great forum, I have learned a lot from reading the many posts.
    Reading taken with DPD kit after shocking:
    FC 25+
    TC 25+
    CYA 85
    Reading before shocking and with older basic chem set:
    pH 7.2
    FC 3.0
    21,000 gallons in ground, kidney shape
    Polaris 280
    Cartridge filter
    22,548
    Re: Yellow Mustard and/or Pollen
    Welcome to TFP.
    Did you test for CH? If not you probably should.
    In fact go ahead and post a full set of test results.
    Jun 2013
    NE Florida
    2
    FAC = 4
    CH = 210
    CYA = 70 (MY test for CYA was around 85, but that was my first attempt at it)
    TA = 90
    pH = 7.2
    Phosphates = 100
    this test was performed by pool store prior to shocking.
    Update - Just left the pool store and was able to return kit and refill a few chlorine jugs. I'll be ordering a comprehensive kit momentarily.
    30,419
    Welcome to the forum. I think you are on the right track. You can get that last bit of cloudiness out but it's a bit of a guessing game until you get your kit.
    Based on your description, I would add about one gallon of Clorox each day until you FAS/DPD kit gets in and you can really tune in your FC levels and finish up to a crystal clear pool.
    All your other actions seem to be just about right.
    22,548
    With a CYA about 85 (I trust your number more) your FC is too low. You need to raise it soon.
    That may be what's contributing to the cloudiness.
