Results 1 to 11 of 11
Thread: New pool test results...
    Apr 2008
    Manitoba, Canada
    17
    Hello,
    We received our test kit and these are the first numbers we got:
    FC - 7 ppm
    CC - 0.5 ppm
    pH - 7.2
    T/A - 370
    CYA 35
    The water is pretty clear, we can see the bottom, but it is slightly cloudy which I am guessing is a result of the high T/A.
    We used the trichlor pucks that came with the pool and Pool Magnet from the pool store to get rid of the iron in our water. We now want to go BBB.
    The pool calculator seems to indicate that we need to aerate the water to reduce our T/A. It's pouring rain right now, should we pull back the solar cover?
    Thanks in advance.
    30' round AGP - 54" vinyl - 80,000 liter (23,000 USG)
    Sta-Rite 150sqft Mod Media filter w/1.5hp Pump
    3 2x20 Sungrabber Solar panels
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Leave it off, that's how the aeration works.
    It'll go faster if you point your return all the way up so that it breaks the water's surface.
    11,969
    I thought your post said "put back".
    Yes, take it off!!! LOL
    Apr 2008
    Manitoba, Canada
    17
    Cover is off and the return is pointed up. Thanks!
    11,969
    Good. When the rain stops, keep an eye on your FC level if you see it drop or the cloudiness turn a greenish tint then dump some more bleach in there because it could be the start of algea. Be sure to run your filter non-stop till the cloudiness goes away.
    Now go put on dry clothes....LOL
    Apr 2008
    Manitoba, Canada
    17
    Will do, the last thing we want now is an algae bloom.
    The lazy, Friday-off pot of coffee has already warmed me up
    Apr 2008
    Manitoba, Canada
    17
    The rain is still falling, the PH is now 7.5, FC is 6 ppm and the T/A has dropped to 350
    The pool calculator is asking for 6 liters of muriatic acid. We have four liters (should have bought more, but who knew?)
    It seems like a lot, and we would like some confirmation before pouring it in. Does this make sense?
    Rockcrawler's Avatar
    El Paso, Texas
    174
    Use Jasons Pool Calculator http://www.poolcalculator.com/ to to determine how much muratic acid to add to lower your PH to 7.0-7.2 this will reduce your TA and then aereate to bring the PH back up to 7.4-7.6
    Rob
    Because you have such high TA you will have to do this process a few times , so yes go buy some acid
    13,000 IG Plaster, 2hp whisperflo pump, 48 sq in pentair DE Filter, 1 skimmer, 2 eyeball outlets, 200 sq ft solar panels on second story, Auto Pilot SWG-36, Polaris ATV Cleaner
    When TA is really high it takes huge amounts of acid to lower the PH. I get just over 6 liters. If you feel at all uncomfortable adding that much at once just add one or two liters at a time, let it mix for half an hour and then test the water to see where that got you.
    Apr 2008
    Manitoba, Canada
    17
    Re: New pool test results...
    After following the advice on this forum and via the Pool Calculator I am happy to say that our water is clear and sparkling!
    As of 9:30 last night:
    T/A - 130
    PH - 7.2
    Cl - 4 - 5
    We aerated all night again and I am assuming that this morning our PH will be closer to 7.5 and all will be well with our pool.
    Now all we need is for a Manitoba summer to finally replace this Manitoba winter and we will be swimming
    Thanks for all your help, both in this thread and everywhere else.
    Congratulations!
