Thread: My Chlorine Consumption is Down Year To Year
    Jul 2007
    Hillsborough, NC
    521
    Last year I logged FC chlorine reading levels, at least till I got tired of doing it in July. This year, for the same week my FC levels are a few points higher. Yes, there are lots of other factors that could be in play but I am attributing it to my automatic pool cleaner. Before I put it in last week, my FC readings were about the same as last year. Since last week, my FC levels are almost too high.
    27' Round Might Sun AG Pool 18000 Gallon Intex Krystal Clear SWG Hayward Pump/Filter on a Timer
    alanpaul's Avatar
    Aug 2010
    South Florida
    227
    Re: My Chlorine Consumption is Down Year To Year
    It sounds reasonable. If your pool cleaner is removing debris from the water, the chlorine has less work to do, hence the chlorine lasts longer. Although other factors, such as pool usage, chemistry and weather can also influence your chlorine residual.
    In any case, it seems like a good outcome.
    Alan in Wellington, FL - near West Palm Beach
    15,200 gal IG, painted plaster, 1988; 200 SqFt cartridge filter, 2013; 1.5 HP 1-speed pump (uprated), 2005; heat pump, 2005;
    soon to repair (dead) SWG AquaRite T-15 cell, 2005, and replace (dead) suction-side cleaner, 2005.
    Almost everything died this winter 2012-'13, and I know we shouldn't complain... but, Arrgh!
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Have you used any product that might also have increased your CYA level?
    Jul 2007
    Hillsborough, NC
    521
    No. The only things that go in my pool are bleach to shock, salt as needed, a dose of Purple Stuff as needed and muriatic acid or borax to adjust PH as needed. CYA was actually low at startup. I have been bringing it up slowly over the last several weeks. I don't put anything else in it - I wasted a lot of $$$ on chemicals before I found this site.
    Jun 2011
    Long Beach, CA
    2,780
    Quote Originally Posted by crokett
    There's your answer, you are getting the proper amount of CYA in the water for your conditions.
