Thread: Muddy pool
    Muddy pool
    Just had a big downpour and mud has envaded my sparkling pool, where do I start?
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Muddy pool
    Welcome to TFP!
    Run your pump 24 hours a day, and brush or vacuum regularly. If there is a lot of dirt on the bottom, you may want to vacuum to waste if you can. Probably good to raise the chlorine level and keep a close eye on it for a while too.
    Re: Muddy pool
    Thank you for your response . This is a salt water pool so it's ok to run the clorinator with the mud?
    SW Indiana
    9,199
    Re: Muddy pool
    Quote Originally Posted by slpelet
    Yes. You may need to supplement your chlorine some.
