Thread: Game sandpro 4511
    Game sandpro 4511
    I am having an issue. I have a 22 foot I text pool along with a Game sandpro filter then a dolor heater and a saltwater generator, the pump was working amazing no issue I back washed it for the first time and now it has a small trickle of water coming from under the big clamp that holds the top on. I have tightened the bolt as tight as it will go and it's still leaking. Anybody have some sort of solution? I have had it for about a month. Bought it brand new.
    22,542
    Re: Game sandpro 4511
    I assume it's leaking at the big clamp that holds the entire top on the filter. If so then you need to take the clamp off and clean and lube the seal with a lot of pool lube and put it back together. It needs to be really clean and lubed in order to seal correctly. Be sure to check it for any nicks or cuts.
    Thank you. Will try that today!
