Results 1 to 11 of 11
Thread: Re-Using Strainer Socks
    Jul 2007
    Hillsborough, NC
    520
    I have been rinsing out my strainer socks, letting them dry and re-using them. Is this a problem? I thought I might be promoting algae growth or some such. They don't cost that much. It isn't the $$$ as it is the time to go get more if I throw out the ones I have.
    27' Round Might Sun AG Pool 18000 Gallon Intex Krystal Clear SWG Hayward Pump/Filter on a Timer
    Jan 2012
    'burbs of Augusta, Georgia
    7,264
    Re: Re-Using Strainer Socks
    <gasp!> I never once considered they weren't meant to be rinsed out and re-used!?
    I change mine almost daily, rinsing the schmutz out with the hose and let it dry out in the sun while I use a different one in its place.
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by YippeeSkippy
    I do the same as YippeeSkippy.
    You're done SLAMing when:
    Jul 2007
    Hillsborough, NC
    520
    Thanks. I figure after I rinse them I can just toss them in some bleach water for several minutes. That would kill anything on them. yes, I know the pool is full of chlorine, but...
    4knights's Avatar
    NE Kansas
    419
    Wow! You guys actually change them and let one dry? I just dump the basket and rinse the sock while still attached to the basket. Figured I'd replace it when it wouldn't rinse any longer.
    Ron- Kansas. IG fiberglass, Riviera 30 Freeform 13600 gallons,
    EasyTouch 4 w/IC20 SWCG, Pentair Whisperflo 1hp, 2 speed 220 pump, Hayward ProGrid 4820 DE filter using Eco Klean instead of DE, 2 Savi Melody 12v 5 color LEDs, Raypack 266k btu millivolt heater, Arctic Armour Mesh custom safety cover (Total self Install) TF-100 test kit w/Magic stir.
    Jan 2012
    7,264
    Quote Originally Posted by 4knights
    I'm not doing it this way for any other reason that I want to pop the lid off the basket, grab it, replace with a different one and get up off my knees as quickly as possible cause when I'm kneeling and reaching down so far to grab the basket like that the cement tears up my pedicure's pretty polish
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,943
    I use ladies knee highs (queen size) from Walmart. The cheap ones in the little plastic shell cost 33. At six stockings for $1, no reason to reuse them.
    chiefwej
    Quote Originally Posted by chiefwej
    I've never used any skimmer sock or the like. When you use the knee highs, do you just stretch it and put the basket in like where the foot would go? Do you tie it off then? Thanks for any explanation.
    POOL: Intex ultra new in 2014 (32 x 16 x 52) (seasonal; on concrete pad covered with 1.5" extruded or whatever foam insulation sheets - ugly, but comfy); added a through-wall skimmer; I add salt for feel. EQUIPMENT: Pentair SuperFlo pump (1HP, 2SPD); Pentair cartridge filter (200 sq. ft); Pentair MasterTemp natural gas heater (400,000 btu) Climate/Location: Eastern Nebraska
    4knights's Avatar
    NE Kansas
    419
    Quote Originally Posted by crek31
    No, the sock or stocking goes inside the basket(basket needs to be between the knee high and the suction)
    you stretch the knee high or the skimmer sock over the basket rim with the material remaining inside the basket. This ensures it doesn't get sucked through your plumbing. It and all the junk stays in the skimmer basket.
    Jan 2012
    7,264
    They're put inside the basket like a paper coffee filter would sit inside the coffee pot's filter basket. Catches small schmutz as well as larger leaves and such, which prevents pool debris from going through your pipes and into the pump and filter.
    During pollen season you'll be amazed at what they catch. Ugh!
    Butterfly's Avatar
    South Carolina
    10,045
    Here: Richard has some pics:
    skimmer-sock-nylon-illustrated-t60819.html
