Thread: New agp pool advice
    Jun 2013
    Alabama
    2
    New agp pool advice
    Hello All. New guy here. New pool. Followed new temporary pool guide using Kem tech dichlor. Im on the 5th day, Just tested. Here are my results
    ph 7.0
    fc 18!!!
    cc 0
    ta 180
    cya 35
    I just added wash soda to bring up ph, but why in the world is fc so high? I plan on following bbb. Thanks, great forum.
    Intex ultra 22'x52" 1 hp. 2650 sand filter/pump. Hayward skimmer. Plan on using BBB. Set up on 6/23/13.
    Butterfly's Avatar
    South Carolina
    10,045
    Re: New agp pool advice
    Welcome to the forum
    It could be testing error? Maybe? :P
    If 18 is correct, it is at shock level and as soon as it drops below 18, you can swim.
    Normal shock level for CYA of 35 is 14 to 18.
    Once the sun hits the pool, it will start dropping.
    How much dichlor did you add?
    You're done SLAMing when:
    Apr 2013
    Battle Creek, MI
    298
    I used the same method to start up my pool and the FC was that high after only two days of using dichlor, although I had added 2-3 cups of chlorine bleach as it was filling but before I could run the pump. Nothing to worry about. It'll come down.
    18'x4' AG Intex Ultra Frame, 6,700 gal., assembled new 2013; Mods: Hayward EC50C90 Perflex filter & 1 h.p. PowerFlo Matrix pump, Fiber Clear cellulose D.E. substitute, Hayward H100ID1 100,000 BTU NG heater, a pair of 2'x20' Sungrabber solar heaters via the original Intex 635T pump, grey Hydro Tools through-the-wall skimmer, Confer steps/ladder system & Cover Free chemical pool cover. The Summer of Mods!
    Jun 2013
    Alabama
    2
    I followed the new pool guide. 1 oz dichlor for every 500 gals. 4 nights in a row. Not testing error, did it twice. No bleach added.
