Results 1 to 11 of 11
Thread: Also can not lower pH
    Azmp1's Avatar
    Jul 2012
    Maryland
    283
    Split by moderator. Make your own thread for your own questions and don't hijack other people's threads. Thanks, jblizzle
    Hey all, dont want to start a new thread...I can't seem to get my ph down as well after a new fill in a brand new pool.
    I filled from my home water supply this past Saturday, as my builder showed up on Monday and we tested the water (Taylor k2005 kit), FC and CYA were at 0 (naturally), TA at 80, TH at 100, but pH pretty much off he charts, definitely way over 8.4
    The only chemicals in so far were: 1.5 gallons of startup-tec (I added 1/2 gallon more by mistake) was told its no problem.
    So, right away (Monday) we added a gallon of muriatic acid and dropped 3 trichlore tablets into a skimmer.
    Tuesday - same pH result - half gallon more of muriatic acid.
    Wednesday - same pH result - 1 gallon more of acid and 25 pounds of calcium chloride to get the TH up.
    Thursday (today) - half gallon more of acid and 4 more trichlore tablets.
    Also about to add cyanuric acid as today is the day I supposed to add it as told by the pool guy.
    I haven't tested yet since I've added more muriatic acid, will test in the morning.
    The water still looks nice and clear, it I'm starting to worry about not being able to get pH down and therefore not having enough chlorine in there. My builder is out of town this week and I can't get a hold of his service manager.
    Maybe this is the normal because its a new plaster... but i dont remember builder mentioning anything, or maybe i just missed it.
    Any suggestions?
    Oh yea, the pool is 19200 gallons, gunite with diamond brite.
    19200gl rectangular gunite/diamondbrite perl pool || Coverpools auto cover || Jandy variable speed 2hp e-pump & Polaris PB4-60 booster pump || Polaris 3900 sport cleaner || Jandy CV filter || Jandy AqualinkRS8 w/Aqualink touch || Jandy iAqualink2.0 || Jandy Watercolors LED || Jandy AquaPure 1400 SWCG || Hayward auto chlorinator (backup) || Raypak 117k BTU heat pump
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,009
    Re: Can't get my PH to go down (Update)
    You can measure pH about half an hour after adding acid. If you add acid and brush, by the time you're done brushing, it's mixed as well as it will ever be, and you can test right then.
    You're living on borrowed time - you need to get some bleach in there to raise FC before it turns green.
    pH and FC are independent of each other, by the way. High FC will mess up the test results, but won't actually change the pH; FC works better at a reasonable pH.
    Azmp1's Avatar
    Jul 2012
    Maryland
    283
    Thanks Richard,
    I will get bleach in there tomorrow (how much?) if pH is still high.
    the question i still have is why in the heck my pH is so **** high and how much muriatic acid i will need to go through to get it down... I'm afraid there maybe another factor i'm missing here thats keeping the PH high... im a noooooob
    Richard320's Avatar
    Jan 2010
    19,009
    Quote Originally Posted by Azmp1
    Thanks Richard,
    It's the new plaster. For that matter, you might have gobs of alkaline dust in the filter, neutralizing the acid.
    Azmp1's Avatar
    Jul 2012
    Maryland
    283
    Ah! Well that explains it!!! Maybe my builder did tell me that, i just missed it. I suppose thats explains it why he left me 8 gallons of Muriatic acid! How much time (and acid) does it usually take for it to finally go down?
    Does brushing has anything to do with it as well? I've only been brushing once a day, since i was told with startup-tec i don't have to do twice a day.
    And i will clean the filter tomorow
    Richard320's Avatar
    Jan 2010
    19,009
    I don't know. I have plain vanilla white plaster. But if I was you, I'd do a search for "Diamondbrite" and maybe startup and see what comes up in history.
    Azmp1's Avatar
    Jul 2012
    Maryland
    283
    Re: Also can not lower pH
    ok will do, also how much bleech would be enough to add for my pool? Thank you for your help!
    Richard320's Avatar
    Jan 2010
    19,009
    Use the pool calculator to figure out how much bleach (depends also on strength of bleach) to raise your size pool to 3.
    Expect it to disappear rapidly without any CYA in the water.
    Azmp1's Avatar
    Jul 2012
    Maryland
    283
    Can you pint me to the pool calculator please. And I will be adding CYA tomorrow as well.
    Richard320's Avatar
    Jan 2010
    19,009
    Azmp1's Avatar
    Jul 2012
    Maryland
    283
    Great thank you!
