Results 1 to 10 of 10
Thread: Hayward Clamp?
    Hayward Clamp?
    Does anyone know where I can get this black clamp that goes around the cartridge filter? This one works, but itís a real pain to remove as itís next to impossible to get a ratchet or wrench on the left side\top of the bolt!
    I believe to model on the filter is C2020L
    2003 Marquis Euphoria - 400gal
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    Re: Hayward Clamp?
    I believe that clamp has been redesigned and you will have to replace the entire clamp assembly. Any Hayward dealer should be able to supply the parts you need. Check online.
    chiefwej
    Re: Hayward Clamp?
    Thanks..
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    Re: Hayward Clamp?
    Shop around, I bought the bottom half of the filter (mine cracked) and found that I also had to buy a new clamp as it came as a package. I didn't pay a lot more than that for both parts.
    chiefwej
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    Re: Hayward Clamp?
    chiefwej
    Mike_W's Avatar
    Aug 2011
    Orange County, California
    142
    Re: Hayward Clamp?
    If you just need the knob, sorry I mean a Hayward Band Clamp Tool, these guys say they have it for $12.99.
    http://www.swimnsaveusa.com/product74503.html
    A good hardware store should have a similar part, but likely they will call it a threaded knob.
    Mike
    ~17' x 34' IG pool with attached spa - 20500 gallons - Gunite with a "pebblesheen"-ish finish
    Jandy iAqualink with iPad and Jandy PDA remote - Pentair IntelliFlo VS 11018 Pump
    AquaRite SWCG - Pentair SMBW 4060 DE Filter - Really Old Raypak heater
    "Wall-E" an Arneson-Hayward Navigator - A couple of Jandy/Zodiac WaterColors LED Lights - Blue-White F-1000 Flow meter
    Re: Hayward Clamp?
    Bump... so I am still having trouble finding this clamp.. I understand Hayward pulled all these because they were defective.. do I really have to spend $1200 on a new filter now?? Argh!
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Re: Hayward Clamp?
    You don't need to spend $1200 on a new filter.
    I'm not sure on the model but I think this may be it:
    http://www.inyopools.com/Products/07501352014438.htm
    Here's the link to the manuals get your manual and you do a Google search on the exact part you need.
    https://www.hayward-pool.com/webapp/...ltersCartridge
    Feb 2014
    Central California
    17
    Re: Hayward Clamp?
    I've purchased several Hayward parts from Amazon at a much better price than anywhere local. On the filter, is it a model C2020?
    If so, according to this parts list : http://www.ereplacementparts.com/hay...83_146934.html
    It would be part - DEX2421JKIT
    Which is out on Amazon - http://www.amazon.com/Hayward-DEX242...d+filter+clamp
    Double check your model number though...
    18K gal, IG Concrete (colored), Hayward C3025 cart. filter, Hayward Tristar 2-speed 1.85 HP pump, pool is 4yrs old, Hayward Navigator XL vac
    Re: Hayward Clamp?
    I have the C2020. But it's the older one and I don't believe the new clamp works.
    http://www.poolzoom.com/hayward-swim...ter-parts.html
