Results 1 to 15 of 15
Thread: Doh! What happened to my water?
    We bought this house about a month ago, haven't switched to BBB yet, just using 3" pucks (two in each skimmer and they last 5-7 days approx.). Water has been crystal clear.. until today. Water is extremely cloudy which I am guessing is high CYA. Only recent change is I tool the four filter cartridges out and cleaned them with a hose late last week. What that cause this? Any idea how to remedy other than partial drain?
    2003 Marquis Euphoria - 400gal
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,067
    Re: Doh! What happened to my water?
    Welcome!
    I'll wager you have high CYA (stabilzer) levels and low Chlorine levels. If you don't get some bleach in there fast, you'll be posting pictures that show a pool this color
    Do you have any method of testing the pool?
    Have you visited
    At this point, we can't even guess what to tell you - we have no idea what the readings are nor even how big the pool is. But it almost certainly involves lots of bleach.
    Test kit on the way.. I was using strips so chlorine levels shouldn't be too low.. forgot to mention that I forgot to put the top piece back on over the filter cartdridges. it's back on there now.. but could that be the culprit? Maybe it has nothing to do with the filter.. I just can't believe the water would turn cloudy so quick!
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    485 posts and no test kit?
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    Feb 2008
    Denton, TX
    5,061
    Quote Originally Posted by harleysilo
    Better late than never!!
    May 2011
    Long Grove, IL
    117
    Quote Originally Posted by jjdurrant
    That could certainly be a significant factor. If you are killing algae but not filtering it out, the water would turn a teal or blue/green color.
    Regards,
    Jay
    Jay
    28,000 gal in-ground hybrid pool with PacFab Superflow 100 sand filter witn VitroClean media, Intelliflo VS pump, Stenner chlorine pump, Raypak R336A Millivolt Natural Gas Pool Heater
    I had a pool a while ago at a different house.. but that was a couple years ago
    I am making progress. I have recycled about a third of the water and am continuing to use powered shock. Water is clearing up and test strips show 10+ ppm each time. Wish I knew he actual number though!
    Isaac-1's Avatar
    SW Louisiana
    6,711
    You have enough posts here to not take this wrong, continuing to use dry chlorine products with a pool that looks like that is sort of like a person that suspects they have diabetes saying I will just finish eating this truck load of candy I have squirrelled away before I go to the doctor and have a check up.
    What's wrong with the dry chlorine as long as it's not long term?
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    What may be wrong is that you already have too much CYA in the pool and adding powdered shock will add more by putting it in.
    Essential Links:
    That's why I am recycling water as well
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    I don't understand...recycling what water?
    Essential Links:
    partial drain, fill, to lower CYA
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Ok..........
    Essential Links:
