Thread: how long to wait after muriatic acid
    I had to add acid to bring down ph. how long do we need to wait to swim?
    Jeremiah Hough
    22,000 gallon, vinyl liner, chlorine, with auto cover
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,058
    Re: how long to wait after muriatic acid
    Just a few minutes. If you poured it into the return stream, it dispersed pretty quickly, and some bodies thrashing around in the water will do an even better job.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Give it a few minutes to circulate (with pump on, of course). Go swimming after that.
