Irishterrier74
32
Hey all,
Pool is looking great. I'm still a little confused about whether I should add borax. Can you explain why I would use it and how much to add. I don't think the TF-100 tests for it, does it?
Thanks
You would need a separate test. It is completely optional. It is really meant to help slow down the pH rise. But some people like that the water is more sparkly and feels smoother ... others do not notice much difference.
I used it just to raise pH, it works well for that, you can also use Washing Soda to raise pH and it won't add borates to the water. I'm not too worried about adding borates to the water, you need 40-50 ppm to be beneficial, but that requires a lot of borax and acid over time to balance. Small amounts of Borax won't help or hinder maintenance of youf pool.
