Thread: Sequestrants for specific metals?
    Jul 2007
    Hillsborough, NC
    525
    I know I have metals in my well water so while I was filling the pool this year I added a sequestrant - Metal Free. However, the water is still colored. It is clear, it is just tinted a greenish/brownish. The coloring appears to be related to me adding the chlorine. I don't think this is alage - there is nothing on the sides of the pool and the water is clear, it is just colored. So do the sequestrants target specific metals and/or does it have a shelf life?
    27' Round Might Sun AG Pool 18000 Gallon Intex Krystal Clear SWG Hayward Pump/Filter on a Timer
    Sequestrants can be made that prefer specific metals but all of them will work to some extent on any metal. If the water is very clear and turned a color when chlorine was added then it is likely because of metals in the water. You might not have used enough sequestrant. Lowering the PH a little might also help.
    Sequestrant lasts a long time in the bottle but it starts to break down once you put it in the pool. When you have metals in the water you need to add maintenance does of sequestrant regularly.
