Page 2 of 2 FirstFirst 12
Results 21 to 30 of 30
Thread: Houston -wheres the bleach
  1. Back To Top    #21
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Houston -wheres the bleach
    Have any of you talked to UNIVAR? So far, they are the only reasonable ones I've found in the Midland/Odessa area that sell to the public. I'm way late in this forum, but I'm really looking into Chlorinating options for my new pool. UNIVAR is a commodity supplier of all kinds of industrial chemicals, and one of the biggest there is.
    Essential Links:
  2. Back To Top    #22
    Aug 2010
    Lake Jackson, TX
    130
    FWIW, I came across some cheap bleach at the Dollar Tree. $1 for 96 oz. It appears to be 5.25%, the bottle is not marked so it makes me a bit nervous about whether to trust it or not. I bought 2 bottles and did a test,
    FC start 2 10:55AM
    FC end 5 12:10PM
    Still debating if it's worthwhile. I don't like the thought of dealing with all those jugs...
    Cost / fl. oz: $0.198 dollar tree vs
    Cost / fl. oz: $0.299 walmart
    Formula: 1 / (1 * 96 * 0.0525)
    25000 gal IG gunite plaster. Built in spa, built 1984.
    48 SF Hayward DE-4800 filter
    1 hp Hayward super pump
    3/4 hp Polaris PB-4 booster pump, Polaris 380
    Taylor K-2006 test kit
  3. Back To Top    #23
    Mar 2010
    Spring, TX
    1,082
    From HEB, I get 8.25% of 121 ounces for 3.50.
    13,000 Plaster IG Pool approx
    Hayward C5030 Cart Filter
    Emerson 1081 EB653 1.0 HP 1.40 S.F. 3450 RPM
    Pool Calculator, Pool School, TF Test Kits
  4. Back To Top    #24
    Jan 2013
    Houston, TX
    1,079
    Dickey
    On the FC 2 to 5 increase is that what you were expecting given 5.25%?
    Could you post a picture of the bottle? Time to go hunting.
    TFP Moderator Chris V. ~16K Pool & Spa, 48NSF DE, IG Plaster Circa 2000, Intermatic PE653, Challenger pump with a 2 speed B2984, 20gal stenner chlorine injection, Houston, TX
    One cannot follow Islam and Christianity at the same time, nor can one follow pool store methods and TFP at the same time.
    Pool School -- Pool Math -- TF-Test Kit
  5. Back To Top    #25
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Quote Originally Posted by mynewpool
    It's 2.98 at Walmart here. Adds up at .52 per bottle.
    Essential Links:
  6. Back To Top    #26
    Aug 2010
    Lake Jackson, TX
    130
    Karmabiker,
    I was expecting 6% bleach with a rise of 3.7 according to the pool calculator. I was also worried it might be old bleach since it's the Dollar Tree. When I saw a rise of 3 I reversed the numbers through the pool calculator and it seems closer to the 5.25%. The other factor here is that I waited 75 minutes to retest to allow time for mixing and procrastination . A better test will be to do it after dark to eliminate the sun light factor. Eventually I'll try it.
  7. Back To Top    #27
    Jun 2012
    N. Houston
    44
    Just got back from Napco on Spring Cypress and I bought a 15 gallon refillable drum for $30 (I thought it was expensive) and filled it for $1.68 a gallon of 10% ($55.20 total).
    16K gal, IG gunite - pebble sheen aqua blue (filled 9/14/2013) , Hayward EcoStar pump, Hayward Tristar Waterfall pump, Hayward cartridge 425, Hayward Goldline Pro Logic PL-PS-8, Stenner Pump, and hayward tigershark qc.
  8. Back To Top    #28
    Jun 2013
    Huffman Tx
    190
    yes there carboy is $$$
  9. Back To Top    #29
    Jun 2013
    Huffman Tx
    190
    since july 4th I have purchased/refilled 3 -15 gallon carboys and the 3rd one is still 1/2 full
  10. Back To Top    #30
    Jan 2013
    Houston, TX
    1,079
    What are the dimensions on the carboy? I'm trying to figure out if it will fit in my outback...
