Results 1 to 11 of 11
Thread: Should I hook pool filler to water softener?
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    A bit of background
    I have very hard water. The fill water CH varies between 150 and 250. Evaporation rates can be an inch or more daily during the summer. Pool stays open and uncovered year round. The net result is my CH levels get very high. My current CH current level is 1,050. I have thus far used what I have learned here to keep my CSI at or near zero and my pool scale free. But as the CH get higher that becomes more and more difficult.
    I have scheduled an RO treatment of the pool, with a goal of bringing my CH under 100. Once this is done, I am considering having my pool's auto fill supply moved to my water softener output.
    Good idea, or not?
    chiefwej
    22,553
    Re: Should I hook pool filler to water softener?
    I certainly think it would be a good idea. You're softener should be able to keep up with the evaporation rate, and with a DE filter you can opt to dismantle and clean it when it needs it rather than lose water to baskwash.
    30,432
    A BIG +1 to what bama said!!
    With the high rate of evaporation in Tucson (do you lose as much as 1/2" daily?) you possibly could skip the R/O and just allow your near zero CH refill to bring CH down.
    Seems like you may get it down to 500 by the end of the swim season if you evaporate as much as I think you might.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    What? Just because he's adding zero CH water doesn't mean the Calcium evaporated. You need a break.
    38,540
    Yup, time to send Dave down for his nap
    30,432
    If anyone needs to contact me, I will be hiding under my desk for the foreseeable future.
    Jun 2010
    Southern, CA
    10
    If topping off with softened water, is there any concern that the sodium (from the ion exchange) will build up?
    I have a salt pool and I'm still baffled as to what happens after the sodium/chlorine get split by the cell (do they recombine back to na/cl?)
    Will all that extra NA eventually cause a problem?
    I'm in Southern CA.
    Very little rain. Never drain off excess water.
    Cartridge filters.
    Fill water is 300ppm+
    Water is now over 1100ppm
    Would one of the "pool softening" treatments solve my problem (for the short term)?
    16,000 Gallon IG, Salt, Pebble-Sheen. All Pentair. Easy Touch automation, Pentair VS 3050 pump, Intellichlor-40 SWG, Pentair Clean-Clear 420 cart filter, Zodiac MX8 cleaner, Roof mounted Solar panels.
    Richard320's Avatar
    Jan 2010
    19,074
    Quote Originally Posted by Rickster1
    I'm in Southern CA.
    Cartridge filters.
    The only treatment that will work is reverse osmosis, which is pricey and very limited in availability. If you live near San Diego, you might be in luck. Otherwise, the cure is drain and refill.
    1100 CH is high enough that you will have a hard time preventing scaling. It might even be impossible if you keep the pH in the comfort zone. You'll need to do something.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Basically yes...if you want to wade into the deep end, here is a post by chem geek on the chemistry: http://www.troublefreepool.com/pool-...628.html#p4367
    mas985's Avatar
    Pleasanton, CA
    11,743
    My chemistry is a bit rusty but I believe it is the water as a solvent which separates (dissolves) the salt into sodium and chloride ions and not the SWG cell. The SWG cell converts the chloride ions into chlorine gas which then dissolves into the water.
    Mark
    Mar 2007
    San Rafael, CA USA
    12,082
    Mark is correct. The sodium from the salt is irrelevant with regard to the SWG system except in providing charge balance and conductivity. The sodium does not change chemically. It is the chlorine that goes from chloride (salt) to chlorine (disinfectant) back to chloride again.
