Page 1 of 2 12 LastLast
Results 1 to 20 of 24
Thread: Best way to cool down pool temp
    Jun 2007
    North Carolina
    82
    We've been in the 90's and I'm shocked at how fast our water temp is rising. I'm afraid that by mid July, it won't even be refreshing. We're supposed to hit 100 tomorrow and we're in North Carolina! We have terrible humidity to top it off.
    What is the best way to cool pool water?
    27' ABG
    Sand Filter
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Running your pump at night will help some. Running a fountain will help more. Anything that encourages evaporation will cool the water.
    Jun 2007
    North Carolina
    82
    I'll try to pick up a fountain then.
    27' ABG
    Sand Filter
    Aug 2007
    Austin, TX
    343
    I have been testing using my solar at night. It has kept the pool in the low 80's. The daytime has been a warm high 90's to low 100's for the last two weeks.
    20k Gunite/Prism Blue-Pebblesheen, Pentair Tagelus TA-100D Sand Filter, Heliocol Solar Water Heater, 2 bubblers and 2 waterfalls installed 2007, 3hp IntelliFlo VS Pump 011018 installed 2013, Aquabot Turbo T4 RC and Stenner 45MHP10 w/The Liquidator container installed 2012.
    Antigua Spa by Artesian Spas: 325 gl, 52 jets, 6 hp 2 sp & 6 hp 1 sp, Circulation System 24 Hour Whisper Pure, Ozonator, LED digital lighting, The Artesian Pillowfall installed 2007.
    Retired: 2hp Pentair Whisperflow, Legend Platinum w/booster pump, PH Adjuster
    Richardson, TX
    287
    We got something like this but ours has a polaris adapter to plug into the wall. Since our jets are on the corners and the polaris adapter is right in the middle it looks great and works well, just run it at night when the air is cooler.
    http://cgi.ebay.com/Swimming-Pool-WATER ... dZViewItem
    I couldn't find the polaris one but I know they make one if you have a polaris.
    My pool works thanks to TFP
    Please support the site! pages/supporters/
    It's cheaper than your first trip to the pool store!
    Richardson, TX
    287
    i also think there is a couple of posts on here of people that have made their own! When I priced out the polaris parts it was cheaper for me to buy it...go figure.
    poolhound's Avatar
    May 2008
    Elgin, SC
    54
    My water temp is now 94, too warm for my preference but OK with my daughter and grandson. I have a homemade fountain (PVC) which does a good job of aerating. I think I will get more cooling by running the fountain at night but probably want to run the filter and LQ during the day, is this correct? I can get more contacts for the timer to split the time I run the pump.
    Does anyone know a "rule of thumb" for how much DE to add to a sand filter, mine is 325#.
    24000gal IG, VL, 1.5 HP, Pentair 60/60D Sand 325#, BBB, Stenner45MHP2 (Replaced Liquidator), Dolphin M400
    Quote Originally Posted by poolhound
    Usually a cup or less... mix with some pool water and SLOWLY add to the skimmer (pump running) until you see a 1ppm rise in your pressure.
    8200 gallon 20' x 48" round vinyl frame pool,
    Intex SWCG, 12" sand filter, 1600gph pump, TF100 test kit
    30,432
    A Pool Cooler in action as we are posting.
    I believe you get better cooling in the middle of the day. The cooling is provided primarily thru evaporation and evaporation would be greatest when the temp/dewpoint spread is the widest...usually about 3-4pm.
    Mine, too, is made from cobbled-together spare pieces of pvc with 1/4 inch hole drilled in the top.
    Jan 2008
    Malaysia
    109
    One way without disturding your water chemistry is to erect big umbrellas at pool edge and move your bar there too.
    Nice fountain you got there Dave.
    8,000 gal IG concrete & tiled lap pool, 1/2 hp pump, 24" sand filter, SWG Auto Clean, whole pool under shed, 3 X 2ft waterfall one end overflow the other end. TF100 Testkit. 80 F Water whole year round.
    Dave,
    Can you post a picture close up of the actual fountain you built? Nice job and thanks for all the ideas for cooling.
    I have a fountain for my spa and could let that spill over into the pool but I was thinking that would cause a huge amount of evaporation.
    My water temp is also climbing fast every day as I get full sun. I wonder how much the evaporation will cost in terms of adding new water? I think my temp is around 90. Is it the aeration or evaporation that cools? If it is evaporation it seems that adding water each day will be costly and it seems that adding the cool water from underground will be one of the components to lowering the temp.
    24,500 vinyl pool, Intellichlor SWG,
    1-IntelliFlo 4x160 for pool & spa,
    1-4x160 for waterfall and Sheer decents,
    Triton II Sand filter, Easytouch control
    whoozer's Avatar
    Apr 2008
    Acton Maine
    633
    For some reason I'm terrible at posting links to topics but...oh well...do a search under pool cooling and look at duraleighs topic on end of summer pool cooling. He has pics and how to build etc. Hope this helps.
    14x33 fiberglass freeform
    Variable speed Pentair intelliflo superpump
    420 Clean and Clear Plus cartridge filter.
    pool-school/pool_calculator , http://www.tftestkits.net/
    Butterfly's Avatar
    South Carolina
    10,045
    whoozer, I think this is the one....
    http://www.troublefreepool.com/viewtopi ... 01&start=0
    You're done SLAMing when:
    dayhiker's Avatar
    Jun 2008
    Pell City, AL
    304
    duraleigh,
    Very cool. Sorry for the pun. I assume this snugs up tight to the water coming back into the pool (don't know the name of the little jets), but what holds it in place? Mine has orifices that can be rotated and directed to different directions. I guess you unscrew this and then the put a threaded piece on the PVC so it's a hard connection to the ject?
    6\8 and already 87 degree water temp.
    The avatar is Spalding from Caddyshack
    18x36 vinyl IG - approximately 24000 gal
    Jandy SHPM1.5 Pump (1.5 HP); Jandy APURE 1400 SWG; Polaris PB4-60Q Booster Pump; Jandy CL340 Cartridge Filter
    (3) 4'x12' Aquatherm solar panels
    Next project, pump sound enclosure and lots of pool landscaping [6tons of stone 8) funnnn]
    Quote Originally Posted by jjparrish
    Thanks whoozer for the heads up and jjparish for the link. I could not get it to come up under the search. Probably because he said "cooler" instead of "cooling".
    I wish there were some close up photos so I could see how he made the PVC device. Post any additional help to build this cooler if you have anything. I am going to try and run my intelliflow 2nd pump on very low speed and push water through my fountain that I purchased with my spa and see if the temp comes down. At 10:20 PM my temp is 90 degrees. Good news is that when I want to use my spa I only have to heat the water 12 degrees 8)
    30,432
    Yep. Once you remove the return eyeball, it's a standard pvc 1.5" thread.
    The rest of it can be made in any shape or form you want. I used whatever I had to make 4 uprights but anything will work as long as you put some holes in it.
    dayhiker's Avatar
    Jun 2008
    Pell City, AL
    304
    I notice your ladder is removed. Mine is right in front of the deep end jet too. I thought it was just a screwup on mine but now I wonder. Is that done on purpose?
    Sep 2007
    Georgia
    30
    I just purchased a small fountain that hooks up to my return. It has been 100+ here in the south and I run my filter from 12-12 so that the fountain is cooling the water during the hottest time of the day. It really does help. My pool is in full sun until about 4:00 p.m. I can also turn the fountain off without having to remove it. I wish I was crafty enough to make my own.
    16 x 32 IG Vinyl
    Sand Filter
    30,432
    Dayhiker,
    I would appreciate it if you would stop pointing out what a lazy bum I am
    Not on purpose, the ladders have been laying beside the pool the last 4 days.....it's just too hot to put them in.
    If yours is in front of a return, I'd say that's a minor screwup on PB's part but nothing that you can't live with. Looking on the bright side, algae likes to hang around ladders and all that circulation around yours probably helps keep it clean.
  20. Back To Top    #20
    dayhiker's Avatar
    Jun 2008
    Pell City, AL
    304
    Yeah, I didn't think it was that big of a deal. It looked like maybe you had to remove your ladder to get the aerator on there so I thought maybe they were supposed to be in front of the ladder for some reason.
    I thought your pool looked big in the photo then saw 25x54. Dang, that's enormous.
