Thread: Cover Problem
    Cover Problem
    Guys,
    I have one of the safety covers that you can safely walk on and so forth, it consists of a number of rectangles that are sawn together with some kind of material stretched along all the seams. The cover is for the pool and the hot tub area. I noticed that over the winter one side of a rectangle that is over the hot top has come apart, mainly the seam that holds it together the stitching all came loose/disintegrated. It just seems to be isolated to that one edge (water collects near that spot in the winter which could be part of the reason). My question is can this be somehow fixed and where should I go or ask ? Replacing the cover would be very costly and I do not think I can patch this up on my own.
    29,000 FreeForm Gunite Salt Water Pool with attached Hot Tub, Jandy DE60 Filter, Jandy Lite2 Heater, Polaris Vac Sweep 380.
    Nov 2007
    Yardley, PA
    17
    Re: Cover Problem
    I had a similar issue 2 years ago with my Loop Loc cover. Keep in mind I am a DIY'r and not in the business. Called the manufacture, the said the UV rays probably decayed the stitching, I sent them photographs. Were willing to give me a pro-rata towards a new cover, 10% of the original cost since the cover was 10 years old. New one would be $6k.
    I took some fishing line and hand stitched the strapping that was loose after I took the cover off. So far 1 year later no problems with that particular section.
    30,000 gallon Sylvan, Hayward 60 sq ft DE filter, IntelliBrite LED Light, Circupool SI45+ SWG, Raypak 400k BTU Propane Heater
