Thread: Borate/Chlorine Question
    I'm fairly new to this and have been getting "pool stored" for awhile...until I came across this site! I have the TF-100 kit, speed stir, salt test kit and borate strips on order so I can stop getting +^#^%#'! With by my pool store. 7 days ago my pool store told me my free chlorine was over 16.59ppm, borate 35, ph 7.4, hardness 219, alk w/stab core. 145.1, cya 33. Today they said free chlorine 2.25, ph 7.6, hardness 217, alk w/stab corr 122, cya 37, borate 0. I non ch shocked my pool, and dropped my swg to 10%. They told me that my 35 borate from last week did not read correctly because of the high free ch reading. Is this true? And w/normal use in 7 days can my free ch go down that much? I have a 28,000, rectangle, auto cover, swg, jany var speed 1.5 (running at 1950rpm 24/7), and heat to 89degrees. I know I need to wait for my kit, but any help in the mean time would be appreciated! Thanks!
    36,000gallon, 20x40, In-ground, vinyl, auto cover, cartridge filter, 1.5hp Jandy Variable Speed, SWG, Gas Heater
    38,272
    Re: Borate/Chlorine Question
    Have you actually added borates to your water? If not, it is zero.
    I am not sure of the interaction between the chlorine and borates with the test though.
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    Quote Originally Posted by MNPoolboy
    What is the CYA level (aka Stabilizer)? With a rational level of 40 and full sun you could drop 1/3 of FC a day.
    - Sent using Tapatalk
    They told me my cya level was 37. Aquajunk test strip says between 0-30. I added two huge 3-5gallon buckets of supreme last summer. Probably added 8-12 inches of water since.
