Thread: Harvest backwash water in rain barrel?
    MiaOKC's Avatar
    Apr 2012
    Oklahoma City, OK
    347
    Anyone harvest their backwash/waste water from a sand filter into a rain barrel for landscape usage? Does anyone have photos illustrating this type of set up? I've tried to search but haven't been successful. Thanks!
    35,000 gallon gunite pool, semi-T-shaped, 29x15 shallow end and 16x22 deep end, built in the mid-1970s and renovated 2013-2014 // Polaris 9300 Sport robotic cleaner // Taylor K-2006 ... Learning as we go and so grateful to everyone here for their help! Our reno thread
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    Re: Harvest backwash water in rain barrel?
    If the barrel is not uv proof the chlorine at least will drop off over time. The idea seems rational.
    - Sent using Tapatalk
    38,301
    Many members backwash directly into their lawns and plants ... without the holding barrel.
    MiaOKC's Avatar
    Apr 2012
    Oklahoma City, OK
    347
    I think the chlorine would be ok on grass or most ornamental shrubs/trees/plants - even at shock level, you are talking "parts per million" so would likely be safe - I'd done some reading in the forums and lots of people use it on their lawns and such. I would probably not use it on my vegetables or fruit trees unless I was desperate, but that's just me.
    Last year I re-routed the blue flat backwash hose from the sewer and am sending the water to the yard (we're on water rationing, seems crazy to send the water down the drain!) but we are on a slope and the water coming out during backwash tends to run over the lawn and down to the street without soaking in. I need to slow it down, hence thinking of the rain barrel.
