Results 1 to 7 of 7
Thread: PB forgot side drain
    My PB left out the side suction drain that accompanies the main MDX drain. How significant is this? How should they remedy?
    38,284
    Re: PB forgot side drain
    Welcome to TFP!!!
    I have never had a pool with a side drain ... unless you mean the skimmer?
    Could you elaborate / provide pictures?
    Dec 2009
    Central Massachusetts
    2,690
    Welcome to TFP!!!
    A side wall suction is pretty standard stuff with quite a few builders, especially in vinyl pools.
    As long as you have a bottom drain and a skimmer, it's fine. I only have a skimmer and a side wall drain. No bottom drain.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    Nov 2011
    Moberly,MO
    1,010
    MDX is a system that is designed to stop entrapment. The sidewall port you are talking about is a relief suction so if something were to block the main drains it would pull water from the side port allowing the offending piece to get away from the main drain.
    Over 30 years in the pool business
    We build vinyl, fiberglass, stainless steel pools
    Certified in Hydraulics
    To be safe there should either be dual main drains, a side wall suction and a main drain, or an SVRS system. If there is just a single MDX drain and no second drain/suction port (skimmers don't count) and no SVRS system then the system is not safe and they should fix it.
    Jun 2013
    Phoenix, AZ
    130
    I'm planning to install the MDX-R3 drain system myself in my new pool. The side drain is an important part of the system to prevent entrapment. You can go to the link below to Paramount's website about the system. I would ask the PB to rectify the problem.
    http://www.paramountpoolproducts.com/products/mdxr3/
    32K gallon 24'x41' IG, 8'x10' spa, mini pebble,
    Pentair equipment [Intellitouch I9, IC-60 SWG, 520 sq Clean + Clear Plus cartridge filter, 3 VS pumps(1 FX, 2 intelliflo)], Dolphin M5 cleaner.
    2 rain shears, 2 water shears, 2 blubbers, 4 laminars, water slide, rock waterfall.
    Aug 2013
    Katy texas
    7
    just curious if/how this was resolved.
    22k,chlorine,cart,finished dec2013,pebble
