Thread: Refill K-2006
    Jul 2012
    Richmond, Va.
    43
    Refill K-2006
    If stored properly do you really need to replace all supplys in a taylor k-2006 kit every year.
    Is there any parts that don't go bad.
    Thanks
    6014 gallons aprx
    cartridge type filter
    summer escapes pool above ground metal frame
    SFS1000 SkimmerPlus filter pump with GFCI=1,500 GPH
    install date: 6-1-12
    Re: Refill K-2006
    Taylor recommends replacing all of the reagents each year. However, we have found that if stored carefully (cool dark place, uniform temperature, never frozen) the reagents will last for two or more years. Certain things go bad well before others. A partial list of the more volatile reagents include R-0871, PH reagent, and the color indicator dyes for TA & CH.
