Thread: Should I shock with the solar blanket on or off?
    Mar 2013
    Central PA
    40
    Actually that's really my question. Just wondering which is more effective. I figured having the cover on would keep the sun from eating the chlorine, however I don't know if there are gasses created that need to be released.
    29k gallon IG guninte lagoon shape.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,988
    Re: Should I shock with the solar blanket on or off?
    Quote Originally Posted by kwolfe
    You will get a buildup of Combined Chlorine with the cover on, which may make you prolong the shock process unnecessarily.
    That said...if the cover's been exposed to algaefied water, it might not be a bad idea to let it get exposed to the shock level for a few hours at least.
