Thread: Hard plumbing a Doughboy AGP
    May 2013
    Hudsonville, MI
    29
    I thinking about converting from the cheapo hoses to schecule 40 pvc. At first glance the fitting on the bottom of my skimmer and the fitting on the return, are set up to have a hose clamped on them. Is this also the right size for pvc, or do I need to come up with some different fittings? I'm pretty sure the "hose barb" on the bottom of the skimmer is molded in.....?
    Thanks
    Jeremy
    18 x 34 Doughboy AGP
    Hayward sand filter(need to look up the model #)
    1 HP Hayward pump(need to find the model on that too!)
    jcowart's Avatar
    Jun 2012
    Labelle, TX
    320
    Re: Hard plumbing a Doughboy AGP
    They are an odd ball size. They have the adapters from their size to 1.5" PVC. They run about 7.00 each. Some have used the rubber reducers found in the plumbing section of hardware stores.
    17500 gallon Doughboy AGP, Hayward DE filter, waiting for the 1.5hp DB pump to go out.
    Learn to take the advice here and be trouble free or use the pool store's advice. "You can't do both and get very far"
