Thread: Shock Process
    Feb 2012
    Maryland
    400
    Shock Process
    Im going to raise my pool to shock level due to me having to leave town (see this post http://www.troublefreepool.com/insta...er-t64277.html)
    Ive read the shock process, and am looking at the Chlorine/CYA chart. I see the warning about not raising FC above 5 if CYA is truly 0, which mine is. So, is it safe to put it at shock level of FC=12 if I add liquid CYA along with bleach? I would put 2 gallons of liquid CYA which would get me just over 30 and then add 5.7 96 ounce jugs of bleach which would get me at FC=12.
    I would try to pour the clorox one bottle at a time in front of a jet slowly, and alternate a bottle of CYA between the first couple bottles of bleach.
    DIY 18x36 IG Vinyl Rectangle with 2 foot radius; Steel Walls. 8' steps w/t 2 step jets; 2 MD, 1 Skimmer, 2 returns; Hayward Pro Series 24 Inch 300# Sand Pool ; Hayward color logic 4.0 LED light; 2" PVC pipe 4 Jandy Valves, Hayward PL-P-4, SWCG
    22,553
    Re: Shock Process
    If you're going to add liquid CYA then add it in front of a return, wait 30 minutes and start adding the bleach. Liquid dissolves almost instantly and there is no waiting period like there is with granules.
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Shock Process
    You can use the liquid CYA, but you could also use Dichlor for the shocking to add both CYA and FC at the same time, at least for part of your CYA if that saves you on some liquid CYA which can be expensive. Not a big deal though for a one-time dosing.
    Is your pool going to be covered with an opaque cover so that it is not exposed to sunlight? If not, you'll still lose chlorine every day even from shocking so you can't be gone for more than a few days if the pool is uncovered. With an uncovered pool and only 30 ppm CYA, you may lose more two-thirds of the FC over a long summer day in southern U.S. That's still better than losing half the FC every hour in direct noontime sun if there were no CYA.
    Feb 2012
    Maryland
    400
    Re: Shock Process
    Quote Originally Posted by chem geek
    I will have a solar cover on, but its clear. I will be able to add more bleach sunday before i leave in the morning, I then should be back Tuesday evening early. So I would have just over 2 full days with no dosing.
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Shock Process
    OK, no problem then. The clear solar cover will likely cut back the UV somewhat -- not completely, but noticeably (perhaps half?).
    Feb 2012
    Maryland
    400
    Re: Shock Process
    Just to circle back, FC held well while I was gone. Came home to a sparkling clear pool! Im working now on getting the numbers all correct and perfect, will post here at some point with my readings and where to go next.
