Thread: vacuum brush styles? which too choose?
    i see so many different style vacuum brushes. i have a triangle one now with brushes around the outsides.
    But i see others with different shapes and the actual bristles are staggered? any difference which type shall i get?
    18x38 IG
    Appox. 85000litres
    Jacuzzi laser sand filter
    1hp pump
    Municipal water
    30,426
    Re: vacuum brush styles? which too choose?
    Do you have a vinyl or masonry pool?
    vinyl liner
    18x38 IG
    Appox. 85000litres
    1hp pump
    Municipal water
    30,426
    Then I think there is little difference in the style of one over another...as long as it's designated for a vinyl pool.
    I will say that I have a vinyl lined pool and I use a vac head with rollers intended for masonry pools. I am not suggesting a roller equipped vac head for a vinyl pool but that I needed the 30" size that only was available with rollers.
    Should you decide on one of those, you must use a lot of caution on your vinyl surface
    im looking for the vacuum brush the u attach to a pool. but like u said i guess theres little difference
    18x38 IG
    Appox. 85000litres
    1hp pump
    Municipal water
