Thread: Cartridge filter blowing cloudy/dusty water when vacuuming
    I have an inground pool approx. 14000 gallons I think. Pump and filter only been running about 2 weeks. Pentair cartridge clean and clear filter and seem to be blowing cloudy/dusty water when I vacuum pool. Any thoughts. It was clean 2 weeks ago and fairly clean water to start with.
    London, Ontario, Canada
    16' x 32' IG steel wall, vinyl lined straight back kidney, 5' deep
    Aquarite SWG, pentair clean and clear cartridge filter, 3/4hp whisperflo pump
    Titan heat pump
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    You are sucking air. It looks cloudy when it comes out of the return. I'm guessing you don't have a good "seal" when vacuming. Is the vacume connection to the skimmer fully attached? The first time I vacumed, the same thing happened to me. Next time when I had it properly connected, I had good suction and the water coming from the return was normal. You may also have a hole in the hose or connections. That's my guess.
    Try adjusting your vacume hose setup and see if you had proper seal/suction.
