Thread: Vacation situation
    Chewbubba's Avatar
    Jun 2012
    Russellville, AR
    127
    Vacation situation
    Finally, FINALLY got the pool up, but I hesitated to put water in it. We are leaving Friday (it's Wednesday night now) for a 3 day vacation. I knew the pool wouldn't even be filled by then (our water pressure isn't very high). But, then my father-in-law pointed out that if I left it dry, and strong winds blew through, my pool would be all over the yard. And the neighbor's yard. Even today while I was working, the wind would pick up occasionally, lift the bottom of the pool and scoot it.
    I thought I'd put a few feet of water in it to keep it from going anywhere, but chemically I'm at a loss. I have no idea what to do.
    Suggestions? Thoughts?
    16x48 Intex Ultraframe vinyl AGP, 2150 gph sand filter/pump (Intex SF70110), Hayward Skimmer, TF-100 test kit
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    Re: Vacation situation
    Your father in law was right.
    If you can get it filled and circulating you can spike the chlorine levels a bit so you have a fighting chance at keeping out algae for a few days. The goal would be to put them higher than normal so when you get back they are just getting to the point of needing to be upped again.
    You'll need to get some CYA in there as well.
    If you can't get it high enough to circulate you can probably add some bleach and give it a real good stir.
    - you need a drop based test kit and the pool calculator to determine levels
    Chewbubba's Avatar
    Jun 2012
    Russellville, AR
    127
    Ok, that sounds like a plan. I've got a little bit left in my kit from last year. (Better order another today before I leave.)
    Thanks!
