Thread: Gel like substance?
    Gel like substance?
    I have been checking my chemistry at least once/day. I am at about 2.5 weeks since plaster. Still another couple weeks before I dump in salt and put in the salt generator. My chemistry has been at the following levels for the last couple weeks:
    CYA=40-50
    CH=220
    TA=90
    pH=7.4-7.6
    I keep FC between 2 and 4 and have only had CC come up non-zero one time... it was 0.5. Using HTH liquid chlorinator product until my SWG is operational.
    I have been using the chart for salt water pool, but I am guessing since my SWG is not yet operational, I should be using keeping FC a little higher between 4-6?
    My main question is... I have a little bobbing thermometer in the pool... my wife saw something on it and asked me what it was... looked like a few small globs of gel... with brown spots/areas in it... anyone know what this is? Am I doing something wrong with the chemistry?
    32K gal, gunite, French Gray DB, IntelliFlo VF, IntelliFlo, WhisperFlo, Quad DE 100 filter, IntelliTouch, IC-60 SWG, IntelliChem, Dolphin M5
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: Gel like substance?
    I would just spray the thermometer with some bleach to be safe and throw it back in the pool. I'd keep FC in the 4-6 range, especially with the summer heat.
    Frog eggs!
    Lizzieann,
    27x54 AGP with Waterfall, 18,500 gallons, Waterway Sand filter- Waterway 1.5 hp -1 speed pump , TF-100 test kit, BBB method.
    30,419
    I think lizzieann nailed it.
