Results 1 to 11 of 11
Thread: Is this right? Return split between SWCG and heater
    Apr 2013
    Central Massachusetts
    174
    So I returned home to my pool install. Fully plumbed and wired now. However the plumbing isn't quite what I expected.
    Let me describe the setup:
    Skimmer and main drain comes into the pump.
    Pump goes out and into the filter
    Here's where I was surprised: Out of the filter goes to another valve, one way goes to the heater (heat pump) and then to the returns on the shallow end stairs. The other way goes through the SWCG cell and to a different return in the deep end.
    Is it normal to split the flow between SWCG and heater like that? And go to different returns? I suppose it shouldn't matter as neither requires a high flow. Just not what I expected... I figured they'd be plumbed in series: pump -> filter -> heater -> SWCG -> returns
    26,000 gal 18x36' IG Vinyl Pool - Hayward S244T Sand filter - Hayward Tri-star 2-speed 1.5HP pump - Goldline Aqua Plus SWCG and Controller with Tcell-15 - Aquacomfort 125K BTU Heatpump - Hayward Color Comfort 4.0 LED - Zodiac MX8 suction cleaner - TF100 test kit
    My Build thread
    Re: Is this right? Return split between SWCG and heater
    No, that isn't normal. On high speed that plumbing should be just fine. It does present some challenges when running on low speed however. It is unlikely you will be able to use both the SWG and the heater at the same while on low speed (and we normally recommend running only on low speed if at all possible). While normal plumbing would not have an issue with this. Of course there is some change it will work even on low speed, but that seems unlikely.
    Your expectations are exactly what I would expect, with the addition of the valve to choose between the returns placed after the SWG.
    4knights's Avatar
    NE Kansas
    419
    I would think it defeats the purpose of the heater, if you are only heating 1/3 of the water going back to the pool it will take a lot longer to heat the whole pool.
    The SWCG is supposed to be plumbed after the heater but depending on brand there is a distance requirement after the heater as well.
    I would call the builder and have them explain their rationale for doing it that way and the concern about not heating all the water returning to the pool.
    (it's kind of like filtering only part of your water)
    Ron- Kansas. IG fiberglass, Riviera 30 Freeform 13600 gallons,
    EasyTouch 4 w/IC20 SWCG, Pentair Whisperflo 1hp, 2 speed 220 pump, Hayward ProGrid 4820 DE filter using Eco Klean instead of DE, 2 Savi Melody 12v 5 color LEDs, Raypack 266k btu millivolt heater, Arctic Armour Mesh custom safety cover (Total self Install) TF-100 test kit w/Magic stir.
    Apr 2013
    174
    The only thing I can think is that the pump is a tristar wet end and even at the low speed its good for 80gpm. I will ask my PB what is up in the morning because it doesn't seem right.
    @4knights - I would think the same amount of heat should go back into the pool whether is split or combined. I would just have "hot" water coming out of 1 return, rather than "warm" water coming out of all returns. My only concern would be affect of water flow rate on efficiency of the heater and SWCG.
    My Build thread
    4knights, the heater has a certain minimum flow rate. Below that flow rate it simply won't work at all, and above that flow rate it will work just fine. There is no issue there as long as the heater is getting the flow rate it wants, even with the plumbing the way it is now.
    MassNerd, You will not be getting 80 GPM on low speed with that pump. Figuring out flow rates exactly depends on some many factors that it is not usually worth the trouble, but I am guessing you might get 40 or 50 GPM, maybe a little more if the plumbing is well designed (and evidence at the moment is that it is not).
    May 2013
    North East Ohio
    959
    However keep in mind that heat pumps also don't like a big differential between incoming and outgoing water...so if you are splitting the flow on low and even if your HP still runs, your flow might be so slow that your water is too hot. The aquacal service rep said 8 degrees difference is about the max.
    I agree, I do not have mine setup like yours...something does not make sense.
    14,750 GAL IG Fiberglass (16 x 33) NE Ohio || Jandy 1HP 2 speed Pump || Waterco MultiCyclone 16 Centrifugal pre-filter (removed due to not working with sand filter) || 30" 575 Lb. Sand Filter || AquaCal 140K BTU Heat Pump || Solar Cover || Inter-fab Adrenaline Slide || GLI Monsoon Solar Cover Reel || K-2006C Test Kit || BBB with Liquid Chlorine Stenner Injection || Rayner Mighty Mesh Winter Cover
    Apr 2013
    174
    I spoke with my pool builder and he is confident there will be enough flow through, at low pump speed, through both the SWCG and heater. He claimed before titanium heating elements, keeping the flow closer to the minimum extended the life of the heaters and might still improve the life with the titanium heater I have. He's done over 100 installations like this with no problems. He's been installing pools for over 25 years and has one of the best reputations in our area, so I'm satisfied to trust him for now. I'll report back after we have everything up and running.
    My Build thread
    I look forward to hearing how it works out.
    Apr 2013
    174
    Well, everything is hooked up and running. So I go out and set the pump to low speed and the heater gives me the low flow warning. I start turning the valve towards the heater path and I pretty much have to turn it all the way to heater to get the low flow warning to go away and for the heater to turn on. Guess I'll be talking to the PB tonight.... A little upset, but the pool build has gone well otherwise. I expect he'll make it right.
    My Build thread
    May 2013
    North East Ohio
    959
    Remember though, HP have a PRESSURE switch vs. a true flow switch. The pressure switch can be reduced, HOWEVER it is absolutely CRITICAL that you don't turn the pressure all the way down. You gotta keep your flow above whatever you HP low flow threshold is. HONESTLY I have NO IDEA how that is going to work with your setup...I say it won't - without diverting 100% of the flow to your HP on LOW.
    Good luck!
    Apr 2013
    174
    An update on my install:
    The PB came back and adjusted the flow detector in the heater. Now I can run both the heater and the SWCG with the pump on low speed and the returns split 60%/40% heater/SWCG. I'm wondering if its possible to adjust the heater's flow rate detector below the recommended level for the pump, but the PB says its ok...
    It does work though!
    My Build thread
