Results 1 to 10 of 10
Thread: First time test results; need help?
    Jun 2013
    Huntsville TX
    5
    Here are the test results from the new TF100 test kit. I have a 27' round above ground pool that was filled with fresh water (from city supply) on Sunday up to about 48" I added stabilizer/conditioner sold to me by pool store on Sunday, Monday, Tuesday through skimmer in a paint thinner sock. The pool has an auto chlorinator and it has the trichlor tablets loaded into it.
    Test results on 6/26/2013 at 715 pm cst:
    FC - 13 ppm
    CC - 0
    TC - 13 ppm
    TA - 300
    CH - 80
    CYA - 60
    pH - 8.2
    Pool calculator recommends muriatic acid and calcium chloride.
    I'm guessing I should turn off the auto chlorinator?
    What else would you recommend, especially pool pump run time (it's been running 24/7 since Sunday).
    The pool water is very clear in appearance.
    Any other info I should provide?
    Thanks in advance,
    T O'Brien
    T O'Brien Huntsville TX
    27' round AG, 1.5 hp 22 Cristal Flow filter system (zeobrite)
    Polaris 65 auto cleaner
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,075
    Re: First time test results; need help?
    Welcome!
    Don't use any more pucks - your CYA is already on the high side and the pucks are just making it worse.
    Yes, you need some acid.
    Your vinyl pool doesn't need Calcium. Save your money.
    Questions about what to use, target levels, pump run time, etc, are all addressed somewhere in Pool School.
    [center:fdo9o1wo][/center:fdo9o1wo]
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    With a CYA of 60, and no SWCG, You don't need any more stabilizer or pucks. Liquid bleach is the best you can use.
    vinyl pools can get by with low CH, not needed. Calcium chloride will run this up.
    Muriatic acid, yes. do 2/3 recommended dose then retest after an hour of circulation.
    And what Richard said.......
    Jun 2013
    Huntsville TX
    5
    Thanks! I'll add a little over half a gallon and then re-test and post! I'm going to try and do this myself so I don't have to pay a pool guy to do it! Hopefully with this forum and all the great info, I can do it!
    Jun 2013
    Huntsville TX
    5
    Okay, wasn't able to retest until now. Looks better?
    FC 11ppm
    TA 210
    CYA 70
    pH 7.8
    Pool calculator suggests adding 32 oz muriatic acid. Should I add it all at once?
    Richard320's Avatar
    Jan 2010
    19,075
    Quote Originally Posted by Tobrienlaw
    FC 11ppm
    TA 210
    CYA 70
    pH 7.8
    How confidant are you of the volume?
    Since this is a new experience - accurate testing and dosing - for you, you should go lightly with the acid and see if the results you get on pH and TA match the estimated effects of adding it. Scroll way down to the bottom of pool calculator and see Effects of Adding Chemicals.
    So, instead of targeting 7.4, maybe target 7.6. See what it did to TA and pH tomorrow, then adjust pool volume if needed. I hope I'm explaining myself properly.
    Jun 2013
    Huntsville TX
    5
    Like this?
    Effects of adding chemicals
    Adding [32 ounces of 31.45% muruatic acid] will Lower pH by 0.45 and lower TA by 7.3
    I'm assuming you mean my pool volume? The max height on pool is 52" and that's to the top of rail. I have the water half way between the top of the skimmer and bottom of skimmer, so I'm pretty close I think.
    I will retest again tomorrow. Should I follow the suggestions that to lower the TA you decrease pH to 7.0 to 7.2 with acid and then raise pH with aerating? I am using the calculator on the web site, I haven't purchased the apple app yet.
    Thanks!
    Richard320's Avatar
    Jan 2010
    19,075
    Like this?
    Thanks!
    Your TA is fine.
    Just check the results for a few weeks to be sure the effects you're getting match the effects you're calculating. If they're not, then you know to increase or decrease the number you enter for pool volume. Otherwise you will go crazy always over or under shooting on chemicals.
    Jun 2013
    Huntsville TX
    5
    Thanks for the help!
    Jun 2013
    Fallsburg, NY
    258
    Like this?
    Thanks!
    Pretty close on water depth for a 27' pool is a lot of gallons to be off for calculating how much chemicals to add. For example 1 inch of water in a 27' round pool is 358 gallons. I'd go get a tape measure and subtract the number of inches from the top of the rail to the top of the water and use that number. If you see your additions making bigger or smaller changes than predicted by the pool calculator, it can be very useful to adjust your # of gallons in the calculator so it can predict better.
    8638 gallon 20'x52" Intex ultra frame round AG. 2650 gph Intex Sand Filter. Intex krystal Klear SWG. (newer model that includes copper ion generation) Hayward 1091LX skimmer, Kreepy Krauly lil shark. Taylor K-2006 w/speed stir and sample sizer. New this year, Intex PureSpa - dichlor-> bleach method for sanitizing.
    New pool, 16'x36' (approx 18000 gal) in ground pool, Haywood DE filter
