Thread: So how many Ibs of Chlorine , how many pints of Acid .
    Like to know how much Chlorine to put in the pool in Ibs on first start up , pure fresh water , and roughly pints / gallons of acid . pool has 16000 gallons of fresh water just filled ready for Chlorine and acid .
    I used Chlorine powder about one Ib and dissolve it in a gallon of water when adding any Chlorine to the old pool is that good ? , whats stabilizer btw I thought it the muriatic acid you add but now not so sure ,? is it some other acid ? ( stabilizer makes the Chlorine last longer } right . one more thing how long do you leave the pump on doing backwash thank you ..
    Had a pool before but adding Chlorine and acid my bad was not very scientific, now started reading the forum I realize its better to learn how to do things properly ..
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: So how many Ibs of Chlorine , how many pints of Acid .
    Try this http://www.poolcalculator.com/
    While you are in the mood for reading, Pool School
    Do you have a good test kit? If not, you really need a good one to know what is going on in your pool. N, I don't mean strips or a chap walmart special. I mean a good test kit.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,984
    The Pool Calculator can crunch the numbers and tell you what to add. You need to know pH,TA, and volume before you can get the acid dose.
    [center:17jjv3k6][/center:17jjv3k6]
    38,271
    Just start reading at the top of Pool School. Start here as you do not understand the chemicals:
    pool-school/pool_water_chemistry
    pool-school/types_chlorine_pool
    pool-school/recommended_pool_chemicals
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    It would be best for you to use liquid chlorine. It only adds chlorine to your pool. Yes stablilzer helps the chlorine from being eaten by the sun. If you insist on using dry chlorine you can calculate how much CYA or Calcium that will add to your pool, but you can't use it indefinitely.
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
