Results 1 to 7 of 7
Thread: algee attack!!!! mom needs your help!!!
    please help i can not keep my chlorine levels up. i am being attacked by chlorine i used the pool caculator and this is what it said. is this okay. i have a 18000 gallon pool, de filter, plaster walls. thank for the help. i'm a mom in trouble, her kid cant swim in the pool and it is 95 here in tx !!!! im using super shock 73%. it seems like i am always having to shock it and algee still comes back in 3-4 days. i have not went to liquid chlorine yet but my plan is to get this right and switch.
    FC 0
    TC 0
    CC 0
    PH 7.5
    TA 150
    CH 220
    CYA 30
    CALCULATOR SAYS
    SHOCK 13OZ
    muriatic acid 42OZ
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    Re: algee attack!!!! mom needs your help!!!
    Where did you get our test numbers?
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,058
    That's because you stopped too soon!
    Your target FC to shock the pool is 13. Using your Cal-hypo 73% (And you won't be able to use it much longer or CH will get too high) you need to add 4 lbs 3 oz. And in an hour or two, you'll need to recheck it and dose it again to get it to 13. And again and again and again and again and again until you pass the three tests in pool-school/shocking_your_pool
    Once it's clear and passes, if you maintain the FC above minimum you will never have to do this again.
    A little inspiration:
    first-time-shocking-with-bleach-t45074.html Check out the pictures!
    pretty-black-pool-t58442.html
    first-time-pool-owner-t61565.html
    a-little-encouragement-for-those-with-algae-and-new-to-bbb-t57137.html
    frog-filled-green-swamp-to-oasis-work-in-progress-t48213-20.html be sure to look at page 2
    before-and-after-t36785.html
    a-final-picture-set-of-how-well-the-bbb-method-works-t33199.html
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,427
    Hi, welcome to TFP! You need to complete the shock process on your pool. I don't know where the 13 ounces of shock comes from. I plugged your test results into the Pool calculator and your shock level is 13 ppm of FC. To reach shock level you would need to add 343 ounces of 8.25% unscented bleach. You would then need to re-test every 1-2 hours and add enough bleach to reach shock level again until the process is complete.
    Where are you getting your test results from?
    Love TFP? Become a
    TFP Supporter!
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Since those are probably pool store number, they all are suspect.
    I would strongly suggest you order a good test kit and test it yourself.
    Household bleach is the preferred method of adding chlorine to pools here.
    im using the Taylor K-2005 Complete Test Kit
    thanks for all the replies !!!!
    Isaac-1's Avatar
    SW Louisiana
    6,711
    If your using the K-2005 then you only need to add the FAS-DPD chlorine test to it to get a good test kit, the DPD chlorine test included in the K-2005 only reads to 5ppm so there is no way for it to test to the levels you need to maintain for shocking, although you MIGHT get away with using it in this case since you have relatively low CYA, if you dilute your pool sample down with 2 parts chlorine free bottled water and 1 part pool water, then multiply your test by results by 3 (it will introduce more error in the test though), your target FC for shock level is 12 ppm at a CYA level of 30 ppm., given the extra error in the test this way I would aim for 15 ppm FC shock level.
    Ike
    p.s. without the FAS-DPD test you will not be able to have enough resolution to do an overnight chlorine loss test (OLCT) to know for sure if you have met the goals of shocking though
