Thread: Can I add bleach?
    Jun 2013
    Ohio
    4
    Can I add bleach?
    So a couple weeks ago my intex swg stopped working. They replaced it, but shipping took about a week. During such time my water quality diminished and i had some green water going on, not shocking. I added some shock, and that helped. Now with the filter a swg running again the water appears to be cleanIng up nicely. It is clear again and smells good. I have not bought the test kit yet, and I know I should and will be soon. Testing with those stupid strips the levels don't look bad at all, but despite the water being clear and my swg running non stop for the last 2 days I am shoing 0 FC. I guessed that with the algea build up all the chlorine being made has been getting use up, so my question is can I add bleach to get my FC up and set my timer back to normal on the swg, or is it better to wait on the generator?
    Intex 8000 gallon
    above ground 1224
    Sand filter SWG
    N.E. Ohio
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    Re: Can I add bleach?
    Yes. Bleach is the suggested way to clear a swamp - as you can see for yourself, a SWG can't keep up with the demand. pool-school/shocking_your_pool tells how. But without a proper test kit, you'll be working blind, and if you hot any snags, no one will be able to help you make sense of it without trustworthy readings.
    Jun 2013
    Ohio
    4
    Thanks a ton. I just ordered my TF100 test kit.
    I'm not going to be swimming tonight anyway, but for future reference, how long is it recomended to wait after adding bleach (assuming you then get a good reading) to swim?
    Intex 8000 gallon
    above ground 1224
    Sand filter SWG
    N.E. Ohio
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    If you add your bleach to the skimmer, or in front of your return, 15-30 min is fine.
