Results 1 to 9 of 9
Thread: What size filter for 15k pool and intelliflo VS pump
    I have a 15k gallon pool and looking to replace some equipment. I have decided on the intelliflo VS pump and a cartridge filter.
    I have a waterfall, 4 jets around a bench and a pool heat pump.
    I am not sure if a 240sq ft filter @ 90GPM would be better than a 200sqft filter @150GPM or what size I should go for.
    I currently has a 120 sqft but with 1.5 inch pipes.
    Can anyone shed some light on this please?
    13000, AG, Plaster, Pentair equipment pump salt, automation, 3hp pump, 11 years old, TF-100 test kit, city water, pool cleaner vac, South Florida
    38,271
    Re: What size filter for 15k pool and intelliflo VS pump
    For a 15k pool, our recommendation would be a minimum of a 222 sqft cartridge filter, the bigger the better ... that is really independent of the pump selection.
    Any reason your want the 3HP monster of the Intelliflo? And not one of the smaller VS pumps from Hayward, or just a 2-speed pump if your electricity cost is reasonable?
    I want to hook up the pump to the Screenlogic 2 to the intelliflo and run super low rpm's for 1/3 of the day, kick up the water flow for the waterfall for 1/3 of the day and back down to the lowest rpm for last 1/3. it would also be nice to really crank it up so the waterfall and the jets can work together at a good flow rate on occasion.
    38,271
    Fair enough, with the bench jets and a water feature, you may have the need for a pretty high flow rate.
    Cool thanks for the info. think I will go for the 240sqft filter
    38,271
    Well wait. Are you saying the 240 sqft filter has a max flow of 90GPM, but the smaller filter has a max flow rate of 150GPM?
    May not matter as you may not be able to move that amount of water through the 1.5" pipe anyway.
    Do you at least have two separate 1.5" suction lines from the pool?
    yes the PDF's on the pentair clean and clear 200 says up to 150gpm
    http://www.pentairpool.com/pdfs/CleanandClearOM.pdf
    and the clean and clear plus ccm240 says 90GPM.
    http://www.pentairpool.com/pdfs/178558MOM.pdf
    I thought it was kind of weird that it would be the other way around.
    I have 3 2 inch suction lines skimmer, vac and main drains
    38,271
    Interesting.
    If you look at the max flow rate specs on the site (not in the manual)
    CC200: Residential 150 GPM , Commercial 75 GPM
    CCP240: Residential 90 GPM, Commercial 90 GPM
    So I think that 150 GPM is just artificially high and not where you would want to be operating given that the commercial rating is lower for the smaller filter.
    Stick with the bigger one.
    And you apparently have PLENTY of suction line available
    cool thanks again!
