Page 1 of 2 12 LastLast
Results 1 to 20 of 32
Thread: Got my new test kit and unsure.....
    May 2013
    Boynton Beach Florida
    16
    new to the school just got my test kit tf101 and loving it but still not sure about results.14k Gal Marcite,IG pool with cartrige filter.Checked my water then went to the pool store to see how right I am.I think I got screwed again.My alkalinity came at 25ppm when I checked it at home it was 120.So I bougth 10 lbs and put it in waited a few hrs and checked again now 160. Am I doing something wrong.
    14K gal,In,plaster, cartage filter 1hp pump zodic g3 cleaner swg.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,380
    Re: Got my new test kit and unsure.....
    Trust your test results. If your test result was 120 and the pool store was 25 and you added 10lbs of increaser and now TA is 160 then the pool store test was wrong. If you are unsure about your results you can always re-test, or post questions here and we will help you out. Go ahead and post your full test results and if anything looks odd we'll let you know.
    Love TFP? Become a
    TFP Supporter!
    Jan 2013
    Houston, TX
    1,079
    ... What Zea said...
    We like full test numbers!!!
    TFP Moderator Chris V. ~16K Pool & Spa, 48NSF DE, IG Plaster Circa 2000, Intermatic PE653, Challenger pump with a 2 speed B2984, 20gal stenner chlorine injection, Houston, TX
    One cannot follow Islam and Christianity at the same time, nor can one follow pool store methods and TFP at the same time.
    Pool School -- Pool Math -- TF-Test Kit
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Overall this should be a cheap lesson about the quality of pool store numbers, as it is something you can adjust over time, not something like CH or CYA that would require water replacement to fix
    jcowart's Avatar
    Jun 2012
    Labelle, TX
    320
    Trust your numbers. 10lb shows an increase of 51ppm so that's about right. So did they sell you 10lbs sodium bicarb. Im sure if you took that same water to another pool store you would get different numbers. Go on and run a full test and post your numbers.... Again trust you testing...
    17500 gallon Doughboy AGP, Hayward DE filter, waiting for the 1.5hp DB pump to go out.
    Learn to take the advice here and be trouble free or use the pool store's advice. "You can't do both and get very far"
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,995
    Welcome!
    I see exactly what you're doing wrong - you're doubting your test results!
    I'll bet that if you haul a sample down to that same pool store now, they'll sell you some pH-minus to get rid of that high TA.
    A couple weeks of testing and dosing and it will all click and you'll be amazed at how really simple it is.
    38,284
    I just want to point out that it is not uncommon for the TA test to be a little high with a new kit ... this is due to the static electricity build-up in the solution. So if you are not wiping the tip after each drop, the drops may end up smaller than normal by jumping off the tip too quickly resulting in a higher than reality result. That said ... this would not account for a 25 to 120 difference ... it would likely only lead to a 20-30ppm difference.
    May 2013
    16
    IN,Plaster 14k waited A week and did a full test cl .05 ph 7.8 fc75 cc 0.5 ta 220 ch 370 cya 50 could someone please explane to me what cc is ??
    CC is combined chlorine, which you do not want in the pool. CC levels of 0 or 0.5 are fine, but anything higher means it is time to shock the pool.
    Richard320's Avatar
    Jan 2010
    18,995
    Quote Originally Posted by novaman
    CC is Combined Chloramines.
    Bleach oxidizes organic stuff - think of it as chemical flame. The CC is the equivalent of smoke. Sort of half-burned stuff. When a fire is going good, you don't see a lot of smoke. When the chlorine is really oxidizing stuff fast, you won't have a lot of CC and you won't smell chlorine.
    May 2013
    16
    Thank You ,Wanted to make sure I was doing it right
    May 2013
    16
    Almost most 2 weeks since I been using my new kit and my pool looks like a fish tank ?? I can't get it to stay blue. cl5,ph8.2.fc80,cc0.ta150,ch290,cya60 I brush and clean the filter almost every day .
    Richard320's Avatar
    Jan 2010
    18,995
    pH is too high. FC is right at minimum for your CYA, so if the CYA is actually higher or the FC has dipped below 5 for any length of time, that's why.
    You need to add acid to lower pH and get going on the shock process. Every minute you delay, the algae will get worse.
    May 2013
    16
    Pool still not clear ?? cl5 ph7.5 fc 100 cc 0ta 120 ch 290 cya 60 I brush the pool and clean the filter at least once a day.
    38,284
    Are you forgetting decimal places? How can you report a CL of 5 (what color is that) and a FC of 100??? If that is true, you have been adding ridiculously too much chlorine and not following the (now renamed) SLAM Process.
    The Correct FC level you should be maintaining is 24ppm ... 100ppm is absurd.
    What is your filter pressure doing? How often are you cleaning the cartridge?
    May 2013
    16
    I just retested and this is what I got.cl 6.0 ph7.5 cc0 ta120 ch290 cya 60.I have been cleaning my filter every day at least once and sometimes more.My filter pressure is 12.What is slamming?? and what do i need to do to fix the pool. please help.
    Smykowski's Avatar
    Sep 2011
    3,065
    Read the link above.
    38,284
    So why in the latest set of test results do you not report the FC?
    What color is the yellow OTO chlorine test (next to the pH test)? In reality you do not need to be doing this test. But your stated results do not make any sense. If the FC was indeed 100ppm using the FAS-DPD test, then the OTO test would likely be a bunch of brown particles floating in the water and nothing resembling a yellow color.
    Read this: SLAM Process
    May 2013
    16
    Sorry the fc I missed it was 95 and the color of the cl is dark yellow.if i am missing any thing please let me know.
  20. Back To Top    #20
    38,284
    One of those test results is wrong.
    How much water are you using for the FAS-DPD test? How much powder are you adding? How many drops are 871 are you using?
