Results 1 to 11 of 11
Thread: cloudy after shocking
    Jun 2010
    Mississipppi
    17
    This is my 4rd year with the pool. Still newbie.
    First year was Baqacil then I switched to chlorine and I am sticking with it.
    Not sure why this is happening. This year every time I SHOCK the pool its cloudy for DAYS I have to back flush to get it clear.
    Years before this year I did not have this issue. I would shock it then I would simply vacuum up some undissolved particles the next day.
    The pool would be clear.
    Right now the PH and ALK are all in OK levels. I don't understand why its soo cloudy for soo long, after shocking.
    Any ideas and tips?
    17,000 gallon Sand Dollar II 24 Round AGP with deep end 4'-7'
    1 HP pump
    Sand Filter
    Check it all out here http://www.seizethepage.com/backyard-oasis/
    Casey's Avatar
    SW PA
    10,446
    Re: cloudy after shocking
    Test results please. We cannot advise you without them.
    Jun 2010
    Mississipppi
    17
    Ok Im not all that fancy I have test strips so when I get home I will test and post results.
    1 HP pump
    Sand Filter
    Casey's Avatar
    SW PA
    10,446
    You pool experience would be so much better if you invested in a reliable test kit.
    ETA: I just looked at the link of your pool and it's very nice. I would even go as far as *fancy*. With that said and the investment that you've put into your back yard oasis, I just don't understand why you wouldn't want a reliable test kit to go along with that nice pool?
    Check the chlorine you are using and make sure it is REGULAR bleach not scented. I also remember someone mentioning not to use a type of bleach as it some type of thickening agent in it and cause cloudy water.
    ProSeries Above Ground 20x4 Sand filter 1 hp
    SkyKid's Avatar
    Apr 2013
    Upstate South Carolina
    137
    Posted by Chem Geek
    Generic, regular, UNSCENTED bleach. NOT outdoor, splash-less, etc. Concentrated is OK, but the outdoor and splash-less varieties have thickeners in them that will foam or cloud your pool, at least temporarily. The newer Clorox regular bleach is now 8.25% whereas it used to be 6% and these are fine to use. Off-brand Ultra bleach is fine, again if it's not a specialty (outdoor, splash-less) bleach.
    14600gal, In-Ground Fiberglass, Haywood s244t Sand Filter, Jandy Apure35 SWG,
    Haywood 2 speed 1hp pump, Haywood Pool Shark, TF-100 Test Kit http://tftestkits.net/
    Pool School http://www.troublefreepool.com/categ...etting_started
    Never been Pool Stored Thanks to TFP
    Jun 2010
    Mississipppi
    17
    Yes I know I need to invest in better test kit, but this is what my Chlorine Pro AquaChek test strips say.
    TC 10+
    FC 3
    PH 7.7
    ALK 130
    Cyanaric Acid 30-50 PPM Ideal range.
    I just shocked the day before with 2 bags of rapid shock from poollife and the tablets I use are sometimes from poollife but I think this batch is from Nu Clo the 7 day tablets. I put them in as needed which is usually 2 tablets in the skimmer ever 3rd day. I control my PH with baking soda.
    1 HP pump
    Sand Filter
    30,421
    My best guess, and it's only a guess because your strips (ugh) don't test CH, is that you might be getting calcium clouding because CH is too high. A pic or two of your pool water would be very helpful.
    Your pool can be brought to crystal clear but it's going to take staying out of the pool store, getting your own kit, (a good one) and learning much more about your pool water chemistry. Here's a good place to start...
    read "The ABC's of Pool Water Chemistry" up in Pool School.
    Do NOT use baking soda to control pH....that's not what it's for.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    The problem is likely the "rapid shock" you are using, looking at the MSDS sheet it is Cal Hypo, which adds calcium as well as chlorine to your pool and is prone to cause clouding issues, a side effect is driving your calcium levels up, once they get too high they can cause calcium scaling, damage to pool heaters and other equipment, etc. This is part of the reason we strongly suggest only using liquid chlorine / bleach for chlorination.
    Ike
    Jun 2010
    Mississipppi
    17
    Ok thanks everyone. Let me review the ABC's and get a nice test kit and do this thing right.
    1 HP pump
    Sand Filter
    Jun 2010
    Mississipppi
    17
    I am going to order my kit right now. I updated my site to reflect two new photos of a lot thats been added around the pool.
    It has cleared up now since I used my strips to the best that I can and the pool calculator.
    Im using the BBB method at this time.
    The last two pictures are new.
    1 HP pump
    Sand Filter
