Thread: Well, that didn't work out so well/Intex/Hayward conversion
    Apr 2013
    Battle Creek, MI
    298
    From the very beginning of this new pool project, we've had this Hayward Matrix Power-Flo 50 gpm pump set to replace the original Intex pump. After filling the pool and getting the water balanced with the original pump, not to mention using my old beehive solar heater to do a little heating, I finally got the Hayward up and running, just to see how it would perform under "normal" parameters before I start adding solar panels and a through-the-wall skimmer.
    At first I had it trying to draw from the pool using the cheap Intex over-the-wall skimmer, which couldn't keep up with the pump's water demands, thus making me speed up the TTW skimmer mod. OK, fine. But the best place to put the skimmer due to water height is going to be between the two Intex wall openings. That's OK too. I've seen other mods here using a TTW skimmer between the outlet and inlet. My problem begins with the fact that I have it in my mind to switch the two, eventually running the pool inlet to the lower hole originally intended for outlet, and using the higher hole for a second outlet to supplement the skimmer. So...
    Today I tried swapping the two, just one outlet from the top hole and one inlet for the bottom hole. And guess what? The top hole alone couldn't keep the Hayward pump satisfied. The strainer basket under the clear cover emptied and pressure dropped to zero. Nothing I did, including nearly shutting off the inlet valve altogether, made a bit of difference. I wound up switching them back and it went back to working properly.
    Why would this be? One difference I can see is that I cut off the built-in screen that comes on the Intex fittings from the original outlet. I cover it now with one of the old blue outlet covers from last year's pool. Could that built-in screen on the top hole be that restrictive? And what about actual water pressure? Is the pressure of the lower hole that much greater that it keeps the pump fed, while the lower pressure of the top hole doesn't? And what does all of this mean for me when I get the skimmer installed? Can I keep the pump fed if I use the skimmer and the top hole? I guess I could figure out a way to temporarily plumb it that way at first to see before I did anything more permanent. I was going to cut the skimmer in a bit closer to the second outlet but I may have to just center it and play it by ear.
    18'x4' AG Intex Ultra Frame, 6,700 gal., assembled new 2013; Mods: Hayward EC50C90 Perflex filter & 1 h.p. PowerFlo Matrix pump, Fiber Clear cellulose D.E. substitute, Hayward H100ID1 100,000 BTU NG heater, a pair of 2'x20' Sungrabber solar heaters via the original Intex 635T pump, grey Hydro Tools through-the-wall skimmer, Confer steps/ladder system & Cover Free chemical pool cover. The Summer of Mods!
    Re: Well, that didn't work out so well/Intex/Hayward convers
    Having the skimmer plus either of the existing connections should be plenty.
    I don't understand why you would want to switch the existing connections around?
    Regardless, switching connections probably failed because of an air leak, not because of a flow restriction. That pump will do fine even with fairly restricted plumbing, but no pump can handle any noticeable amount of air getting drawn in with the water.
    Apr 2013
    Battle Creek, MI
    298
    Here's my thinking: I'm concerned, having never had a skimmer through the wall, that the flow of water into the pool near the surface that close to the skimmer would have a negative effect on the skimmer's performance. I have no experience with it, and I'm kind of grasping at straws here. And if the inlet was in the lower hole, I was thinking I could aim the fish eye downward and help agitate the bottom of the pool. That's it really.
    Having an amiable return is a really good thing. Given that it can be aimed, it really doesn't matter where it is. Right next to the skimmer is more of a problem if it only goes straight out.
