Thread: White belt around middle of pool
    My son and I put up our pool and made sure the legs were inside the rope along the bottom of the pool - got the pool full this morning and realized we did NOT put the legs on the inside of the white belt going around the middle of the pool!! Besides draining the pool and starting over, any suggestions? I'm assuming the legs need to be inside of the belt for support (we had the legs inside the belt last year). Would a pseudo band made of duct tape around the outside of the pool hold the legs in or is that wishful thinking? Our pool is 22x52. Thanks much!
    SkyKid's Avatar
    Apr 2013
    Upstate South Carolina
    137
    Re: White belt around middle of pool
    Welcome to TFP
    If it was me I would bite the bullet and drain the pool
    Better to do it the right way than to invite disaster to come by and say hello
    14600gal, In-Ground Fiberglass, Haywood s244t Sand Filter, Jandy Apure35 SWG,
    Haywood 2 speed 1hp pump, Haywood Pool Shark, TF-100 Test Kit http://tftestkits.net/
    Pool School http://www.troublefreepool.com/categ...etting_started
    Never been Pool Stored Thanks to TFP
    That's what I was afraid of - I tried Bungee cord but don't feel comfortable doing that. It makes more sense to drain and start over...grrrr... oh well! The joy of summer!
    Casey's Avatar
    SW PA
    10,423
    All it takes is one missed step to make a do-over.
    Jul 2009
    S. California
    157
    If you have the new style belt as pictured below, then you are OK to leave the legs as pictured. This was how mine came from Intex and how it was pictured in the instructions. Although, nowhere did they specifically say which way they should go
    If you have the old style belt without the leg loops then I do believe you need to have the legs inside the belt.
    Good Luck!
    Jim
    18'x 52" Intex Ultra Frame AG pool
    7100 gallons
    1600 Intex sand filter
    TF-100 test kit
    BBB method for four seasons
    Former 18' Easy Set owner
