Thread: fill water orange with iron
    Jun 2013
    Saskatoon, Saskatchewan, Canada
    40
    I just filled the pool, I think my test kit will be in the mail today or tomorrow. And we live on a farm so I use raw water from the well to fill the pool. It's quite orange and I'm just filtering it now to remove the iron (doubt it's really doing anything). But I was reading in pool school about removing the metals and it mentioned sequestrants. How do I use that? Is that the same as adding a chelating agent?
    Any recommendations for orange irony water?
    16' x 48" intex ultra frame above ground pool 5000g
    one speed Filter Pump with 1,500 gallon (5,678 L) per hour flow rate
    340g FreeFlow Solstice Spa, 1.5 hp two speed pump, 50 sq ft. filter
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: fill water orange with iron
    When you have metals in the water, you will need to use regular doses of a sequestrant to prevent the metals from forming stains. Sequestrants bind to the metals and prevent them from depositing as stains - they do not remove metals from the water. Dose according to the directions on the product label. Sequestrants slowly break down in the pool, so you need to add more regularly to maintain the correct level.
    Sequestrants based on HEDP, phosphonic acid, or phosphonic acid derivatives are the most effective. ProTeam's Metal Magic and Jack's Magic The Pink Stuff (regular), The Blue Stuff (fresh plaster), and The Purple Stuff (salt) are some of the top sequestrants. You can also find many other brands with similar active ingredients, some of which may be less expensive.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Do you have a better source for fillup? If you do, I would really suggest doing that. I know, easier said than done and I see you are out in the country so it may be impossible. If you can see that much Iron, it is a bunch, and may stain badly.
    Essential Links:
    Jun 2013
    40
    The only way to get different water would be to bring in a water truck from the city but . . .$$$
    Have you ever heard of a product by bioguard called Pool Magnet? I've heard somepeople have success with it, but I'm SO DONE with pool stores right now!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    Try the search function for rust or iron.
    Some people have had good luck putting layers of paper towels in the skimmer basket to trap the rust particles. Someone else recently made some sort of prefilter using pillow batting in a bucket. The more you can remove physically as rust particles, the less you'll have to deal with chemically. Also, we're waiting to see the final results in this thread:
    ferri-tabs-slime-bag-experiment-review-t62508.html
