Thread: laser level recommendations
    Mar 2013
    Missouri
    40
    I'm starting to work on the final finish leveling for my above ground pool and just wondering if anyone had any good recommendations for a decent laser level that wouldn't be to expensive but would still do a good job.
    Also from those of you who have used them, was there much of a problem seeng the laser in the sunlight or how you dealt with that. I'm thinking of going this route to try and be as accurate as possible.
    RD
    Unfinished Sharkline Matrix owner
    25,000 gallon, 33'x54" Round AG Sharkline Matrix, 26" sand filter, 2 speed, 1 hp Pentair optiflo pump
    Medic3's Avatar
    Jun 2011
    Missouri
    42
    Re: laser level recommendations
    I use a couple of different types. The first one is a Craftsman straight single line laser level. The other is a laser level that hangs from an adjustable tripod that has built in bubble levels, it throws out a 360 deg laser line and works pretty good for bigger jobs. Both come with red glasses to help you see the light. The tripod type would work the best of the two. Personally, I would use a builders transit level for a more accurate job.
    20,000 gal. 27' AGP
    Hayward 18" sand filter with 1 hp Hayward Matrix pump
    A convinced BBB user and TFP fan
    I think it would be best to rent one. I went with a water level to do my leveling. I read another users thread with him using a water level and I think it worked well for me. I know the reviews of the cheap lasers have the same complaint, can't see the laser in daylight. Best to rent an industrial level laser from a rental store.
    21' Round 48" Deep Doughboy Timberline III, 9100 Gallons
    Using 80lb Media Master sand filter and 1HP Powerpak II.
