Thread: Vacation for 5 days - how to project FC loss
    Sep 2010
    Sacramento, CA
    12
    I recently learned the hard way that FC loss is not linear or constant. At a target FC of 5 ppm, I was losing about 2-3 ppm per day, so I thought that for a 5 day vacation, adding 3x5=15 ppm would be plenty of chlorine. But it was not enough and I got lots of algae.
    I read some posts and learned that FC loss is closer to a percentage of FC. It looks like my loss is around 50% per day. So for another upcoming vacation of 5 days, I am thinking it will be impossible/impractical to add enough liquid bleach alone. What do you suggest I add? I do have some trichlor pucks, but the floater always gets stuck on the ladder. I am thinking of somehow tying up the floater so it has some room to roam but does not reach the ladder. I do not have a cover. Any suggestions? Thanks!
    FC 5.0
    CC 0.0
    pH 7.5
    TA 80
    CH 60
    CYA 40
    Sacramento California
    UN1017's Avatar
    May 2012
    Sacramento, CA
    288
    Re: Vacation for 5 days - how to project FC loss
    Quote Originally Posted by lmleonard
    FC 5.0
    CC 0.0
    pH 7.5
    TA 80
    CH 60
    CYA 40
    That's what I would do.....unless you can have someone stop by and throw some bleach in for you. That's where an SWG or a Liquidator would be handy. You do have some wiggle room on your CYA. You may even benefit if it gets closer to 50.
    15'x30' IG - Roman-style - 14K - Pebble Fina Classico
    Filter: Jandy CL460 Pump: Jandy Stealth SHPF1.5 SWG: Jandy AquaPure 1400 Cleaner: Jandy RayVac Test Kit: TF-100 w/SpeedStir
    Chlorine/CYA Chart----Extended Test Kit Directions----SLAM
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,643
    do that and you'll be fine, especially if you can have someone just stop by only once midweek and dumpa couple gallons of bleach in for you.
