Thread: Pool is milky cloudy
    26,4000K gal, AG,1.5 hp(Hayward), sand filter, 12 yrs old.
    FC-low, CC-ok, Ph-low, TA-ok, CH-na, CYA-low
    pool is milky cloudy
    Jun 2012
    Howell, NJ
    977
    Re: Pool is milky cloudy
    "Low" and "OK" doesn't tell us anything. We will need actual numbers from your own test kit to help you. You will need either the K-2006 or TF-100, which can be found in my signature. With that being said, you will probably need to follow the shock process, which is also linked to in my signature.
    John
    7 year old ~13,500 gal 24' AGP with 1.5 hp Proline pump, 150 sqft Pleatco cartridge, filled with well water with pH of about 4.5.
    Wanda the Whale pool vacuum, home made heater, Taylor K-2006
    Cloudy Pool? 1) Order test kit. 2) Follow SLAM
    New to TFPC? Read Pool School a few times, then post questions. PoolMath will help with chemical additions.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,657
    Those "lows" don't mean much, Can you post actual test results? But if PH is low, you can aererate it. If FC is low, you can add bleach. Get CYA to 30 or so. See the chlorine/cya chart in pool school to match your FC levels to it and run the pump 24/7 to see if it clears any.
