Thread: Question about when to shock
    Hi
    2nd year using TFP, and due to TFP and my Taylor test kit, my pool has never had better water quality or required less chemicals.
    I don't use the frog, threw away old pool perfect, ultra bright, some other stuff from Leslies.
    I do use some pucks and old powder until the CYA gets over 35, then go to 100% chlorox - 1 jug every 2 or 3 days.
    baking soda to raise TA if it drops below 70, CH is 220, ph is 7.6
    my question is about shocking and backwashing periodically.
    do you ever need to shock if the FC is kept between 2 and 6 and CC is always 0, CYA is 30/35 and everything else is in balance?
    also should you backwash every 3 or 4 weeks even if pump pressure has not risen more than 7/8 lbs?
    thx
    24K gal, plaster, concrete decking, cantelivered coping, 20 years old, raised attached stone spa - 1 1/2 HP purex triton pump, 3 yr old 48 sq ft Pentair DE filter with multiport, Polaris 380 w/pump, 2 yr old Pentair mastertemp 400k heater - live in southeastern PA outside phila.
    Jun 2013
    Hartland, MI
    67
    Re: Question about when to shock
    From what I've read a shock is never necessary if your cc level stays below 0.5 and the water is clear and a backwash is only necessary when the pressure rises.
    24'x54'' AG
    Appox. 13800 gallons
    150lb Hayward sand filter
    1.5hp pump
    Well water
    Shocking is only needed when something goes wrong.
    Backwash when the pressure increases 25% over your starting pressure.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,966
    Many of us have gone years without the shock process. My pool is never closed - it just gets too cold to swim in.
